    Jul 2010
    Germany
    Hello,
    I use Redo 5 since some years, last week it works fine.
    But now it shows a strange picture
    [Attachment 81383 - Click to enlarge]
    [Attachment 81384 - Click to enlarge]
    The preview pictures down looks normal but the standard screen are out of color and have other errors
    Any idea?
  2. This mpeg2 video does play normal with media player or vlc player?
    Jul 2010
    Germany
    Yes
    Maybe solved now.
    I had an complete image of the Installation, restored it and it worked OK.
    After some time and restart I had the same problem again. So maybe an Windows-Update?
    I had a suspicion and go to the device manager, restored an older driver for the Intel UHD Graphics HD770, one from February 2024, now Redo works again
Name:	Treiber fehlerhaft Redo.PNG
Name:	Treiber funktioniert Redo.PNG
  4. Member The_Doman's Avatar
    Feb 2004
    Netherlands
    Originally Posted by Wischmop View Post
    Maybe solved now.
    Strange problem indeed, may be indeed a graphics (preview) issue?
    If it happens again you could try editing/saving a clip and see if the resulting file is ok?
    If you want to prevent Windows update the intel adapter (or any other device) you can block the updates by device-id:
    Tenforums: Prevent Windows Update from Updating Specific Device Driver
    Jul 2010
    Germany
    I will try it if it happens again, but I hope it will not happen again
    Normally Updates are good because of some reasons, so I don´t want to avoid it generally.
    May 2005
    Australia-PAL Land
    I've had trouble caused by the Intel driver for my UHD770 in the recent past. An update disabled my "wake up on Mouse/Keyboard movement". Dodgy brothers.
    Jul 2010
    Germany
    I have some Intel systems @home and @my job, overall I can say I had less driver-trouble with many Intel-systems than a few AMD-systems
