What the title says really; I've followed the various guides on here and I have been able to find the stream.mpd and download the files successfully with yt-dlp, but I am running into a wall getting the keys to decrypt.
I've installed Tampermonkey and the relevant scripts, and as far as I can tell I'm finding the correct pssh and license urls, but I am getting 401 errors from keysdb when trying to get the key. Are there any optional tools I can run locally instead of keysdb, since IPs might be the issue?
Video URL?
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Several; including these two:
https://npo.nl/start/video/eurovisie-songfestival-1970
https://npo.nl/start/video/25-jaar-eurovisie-songfestival -
(I can't really give you the download command with the mpd since it's tied to your IP)Code:
--key da7892e5a3634141397c20892eef89dd:74276f412134984946baa84bf34bfb05 --key d9c55f1691aa758aa1450a9a0fb39c0c:cac8e4c9629da5fe44ed25055df504b6
You can try any of the 4 key extractors: @foxrefire's addon, @cdrm project's forxrefire modified addon, @angela's hell noob pack or @larley's fetcher
If you have the right VPN and you can watch content easily on that site, you can also use a batch downloader for npo.nl start:
Or if you're old fashioned, you can always write your local custom script ¯\_(ツ)_/¯. It's explained in the sticky threads. Keep in mind, you have to do the downloading with the same IP that you use to obtain the mpd.Code:python widefrog.py "https://npo.nl/start/video/eurovisie-songfestival-1970" python widefrog.py "https://npo.nl/start/video/25-jaar-eurovisie-songfestival"
the amazing FoxRefire guesser work fine. this key for eurovisie-songfestival-1970 (just to example)
Code:da7892e5a3634141397c20892eef89dd:74276f412134984946baa84bf34bfb05
Thanks! I tried the FoxRefire guesser addon now, but I'm still getting the 401 error: https://ibb.co/RD9bwhH
Is there something I'm doing wrong that I'm not seeing? -
your error is about cdrm guesser (and error for me too)
i've talk about FoxRefire guesser. and this work fine
help with getting drm keys
By bittersweet in forum Video Streaming DownloadingReplies: 19Last Post: 3rd May 2025, 17:12 -
need help to get the drm-keys from a vtm program
By speedbob in forum Video Streaming DownloadingReplies: 60Last Post: 10th Oct 2023, 17:48 -
Download from Npostart DRM protected file
By Meerwater in forum Video Streaming DownloadingReplies: 2Last Post: 4th Oct 2023, 03:09 -
streamlink + DRM keys
By skipmack46 in forum Video Streaming DownloadingReplies: 6Last Post: 6th Aug 2023, 18:35 -
DRM keys
By David-XX in forum Video Streaming DownloadingReplies: 8Last Post: 14th Oct 2022, 17:27
