Hi all:
I have a large library of movies and TV shows. They are all in MP4 H264 format, with some older ones being in MPEG-2 format. They all also have separate .srt subtitle files.
I would like to do batch conversion to MKV format (without any recompression), where I can mux the video and subtitles into one file and edit tags and chapters.
What is best app these days for this? Please note I'm looking for a GUI program; no command line stuff.
Thanks for the help in advance!
I use MKVToolNix GUI. Just add the video and subtitles in the "Add source files" and then "start multiplexing". Make sure you selected the output folder.
It is really fast. You can also create chapters if you want.
I haven't done any batch processing as I prefer to check each completed task is perfect.
MKV file, compress or downsize audio, what app or settings?
By PetitPois in forum Video ConversionReplies: 1Last Post: 2nd Feb 2024, 12:59 -
Is there an App can batch mux mp4 and srt files into MKV on MacOS?
By shruru in forum MacReplies: 4Last Post: 21st Jun 2023, 17:48 -
What app can I use to tell me if an .mkv movie is x264 or x265?
By HartsVideo in forum Newbie / General discussionsReplies: 25Last Post: 19th Oct 2022, 08:17 -
How to setup an MSYS2 building environment
By El Heggunte in forum User guidesReplies: 3Last Post: 10th Jul 2022, 01:35 -
Building a new PC : Any advice?
By beavereater in forum ComputerReplies: 8Last Post: 30th Jun 2021, 19:21
