Same allhell3.py accuracy - it will get everything - but this version wrapped in a gui.
Copy/Pasting is now much more straight forward
Paste mpd
Paste license cURL
Enter Save Name
Click 'Get Keys' to process.
Stop there or click 'Download' to have N_m3u8DL-RE to do its work.
[Attachment 81160 - Click to enlarge]
[Attachment 81161 - Click to enlarge]
Update 15/08/2024 added init parser to the GUI
Update 20/08/2024 added lower Diffie-Helman security context as an optional script, to match sites using short key lengths.
https://files.videohelp.com/u/301890/hellyes6.zip for the complete updated pack
Results 1 to 30 of 263
Noob Starter Pack. Just download any Widevine media! Over 31,500 downloads for V6!.
https://files.videohelp.com/u/301890/hellyes6.zip -
Made two identical threads in error. Please continue to use this one and disregard the other until the mod , (I wish) removes it.
The program runs normally
Places that can be changed
Use absolute path
original document:
WVD_PATH = "./device.wvd"
WIDEVINE_SYSTEM_ID = 'EDEF8BA9-79D6-4ACE-A3C8-27DCD51D21ED'
Unaffected change:
WVD_PATH = "C:\\......\\AllHellGui\\HellYesGui\\device.wv d" Disk character at will
original document:
n_m3u8dl_re_command = f"N_m3u8DL-RE '{mpd_url}' {keys} --save-name {self.video_name_entry.text()} -mt -M:format=mkv:muxer=mkvmerge"
self.n_m3u8dl_re_output.setText(n_m3u8dl_re_comman d)
subprocess_command = ['N_m3u8DL-RE', mpd_url] + keys.split() + ['--save-name', self.video_name_entry.text(), '-mt', '-M', 'format=mkv:muxer=mkvmerge']
self.subprocess_output.setText(str(subprocess_comm and))
Unaffected change:
n_m3u8dl_re_command = f"C:\\......\\AllHellGui\\HellYesGui\\N_m3u8DL-RE.exe '{mpd_url}' {keys} --save-name {self.video_name_entry.text()} -mt -M:format=mkv:muxer=mkvmerge"
subprocess_command = ['C:\\......\\AllHellGui\\HellYesGui\\N_m3u8DL-RE.exe', mpd_url] + keys.split() + ['--save-name', self.video_name_entry.text(), '-mt', '-M', 'format=mkv:muxer=mkvmerge']
Disk character at will!!!
Another thing to note is that
You just need to put mkvmerge.exe in the same folder as. py to run normally.
All the above operations are Windows.
thanks
Thanks to A_n_g_e_l_a at the same time.
suggestion:
It is convenient to package it into exe, but this requires a custom program path. -
If I were to package it as an exe, that would be a big security risk for you, as I, or anyone else passing the script on, could add code to look for your bank or crypto passwords and secretly send it on somewhere.
If you want an executable you may make your own version from my code. https://www.analyticsvidhya.com/blog/2024/01/ways-to-convert-python-scripts-to-exe-files/
I've not tried any of these so mind how you go.Noob Starter Pack. Just download any Widevine media! Over 31,500 downloads for V6!.
i am ignorant..i have python 3.12 installed in my pc(windows 10) how i can use your program?
I proof some hours to open this py program..i also converted this on a exe file but when i proof tò open nothing happen. Can someone help me? What i Need tò use that script?
ok I solved everything.. some modules were missing that prevented the program from starting. I've already done some testing and it's truly incredible! thank you with all my heart
I rarely use mkv format so I changed the script to mp4. Also manually added the 2 modules from requirements and put everything in the same venv folder and it works perfectly. Thanks to @A_n_g_e_l_a
Though it is a minor hiccup and dosnt automatically detect mkvmerge.exe from PATH. -
Everything is open to editing - that makes a script so wonderfully uesful. Mkv has slightly smaller file-size; those who data-hoard prefer it.
Mkvmerge would be found automatically, if on Path as you say. I'd check your Path. In terminal just enter mkvmerge and it should respond with help text. If it doesn't look at Path again.Noob Starter Pack. Just download any Widevine media! Over 31,500 downloads for V6!.
Mkv has more advantages: combination of allowed/accepted codecs over mp4, much better support for subtitles.
Thank you for your work, I registered to leave it written. (It works from MAC)
[Attachment 81258 - Click to enlarge]
All command line programs I use, even those intermittently are by default added to path without exception because I save them on one drive and operate from another which is convenient for me.
That said, I got it to work finally maybe there was a typo I made after multiple edits and re-edits.
Many thanks once again.
Hi, I am trying to use this for VdoCipher but not getting the desired keys. @A_n_g_e_l_a Could you pls throw some light on this?
first of all big thanks nice work bud with a get keys will be very easy if you can intergrade WidevineFetch from larley
https://news.now.com/home/live
Cannot run, EMElogger recognition is no problem
[Attachment 81439 - Click to enlarge] -
root@shy:~# curl https://ewcdn04.nowe.com/session/10-df94688d2240368ecc34bf6d30639/Content/DASH_VOS3/Li...ef6_1723635072
-bash: syntax error near unexpected token `('
root@shy:~# -
Can't see how that would bring advantages. Copying the license as fetch is little different from copying license as cURL. And keys on their own are quite useless unless you have the thing the key fits.
To download you must have the mpd. So you are always going to need two copy-and-pastes.
(for the pedants - yes I know - unless a HAR is used.)Noob Starter Pack. Just download any Widevine media! Over 31,500 downloads for V6!.
Keys are supposed to be quite useless?
Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2 -
I don't want to hijack anyones thread, so I'll let Angela help you out
Yes give me the result of this 'curl <url of the mpd>' in a terminal window. I can't see https://news.now.com/home/live from my house.
curl 'https://ewcdn04.nowe.com/session/10-df94688d2240368ecc34bf6d30639/Content/DASH_VOS3/Live/channel(VOS_CH332N)/manifest.mpd?token=c93d2665a1c84d2390e675cbb8732ef6_1723635072' <?xml version="1.0" encoding="UTF-8" ?> <MPD profiles="urn:mpeg:dash:profile:isoff-live:2011" type="dynamic" availabilityStartTime="2023-10-18T06:05:35Z" minimumUpdatePeriod="PT4.0S" minBufferTime="PT4.0S" publishTime="2024-08-14T08:26:46Z" timeShiftBufferDepth="PT60.0S" suggestedPresentationDelay="PT4.0S" xmlns="urn:mpeg:dash:schema:mpd:2011" xmlns:cenc="urn:mpeg:cenc:2013" xmlns:mspr="urn:microsoft:playready" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:mpeg:dash:schema:mpd:2011 DASH-MPD.xsd"> <Period start="PT0S" id="2"> <AdaptationSet mimeType="video/mp4" startWithSAP="1" segmentAlignment="true" par="16:9"> <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc"></ContentProtection> <ContentProtection schemeIdUri="urn:uuid:9a04f079-9840-4286-ab92-e65be0885f95"><mspr:pro xmlns:mspr="urn:microsoft:playready">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</mspr:pro></ContentProtection> <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed"></ContentProtection> <SegmentTemplate timescale="10000000" presentationTimeOffset="0" media="$RepresentationID$_Segment-$Time$.m4v" initialization="$RepresentationID$_init.m4i"> <SegmentTimeline> <S t="260148240443050" d="40000000" r="14" /> </SegmentTimeline> </SegmentTemplate> <Representation width="480" height="270" frameRate="25" codecs="avc1.4d401f" scanType="progressive" sar="1:1" id="1697609122858item-01item" bandwidth="200000" /> <Representation width="640" height="360" frameRate="25" codecs="avc1.4d401f" scanType="progressive" sar="1:1" id="1697609122858item-02item" bandwidth="600000" /> <Representation width="1280" height="720" frameRate="25" codecs="avc1.4d401f" scanType="progressive" sar="1:1" id="1697609122858item-03item" bandwidth="1450000" /> <Representation width="1920" height="1080" frameRate="25" codecs="avc1.4d4028" scanType="progressive" sar="1:1" id="1697609122858item-04item" bandwidth="2340000" /> </AdaptationSet> <AdaptationSet mimeType="audio/mp4" startWithSAP="1" lang="ch1" segmentAlignment="true"> <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc"></ContentProtection> <ContentProtection schemeIdUri="urn:uuid:9a04f079-9840-4286-ab92-e65be0885f95"><mspr:pro xmlns:mspr="urn:microsoft:playready">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</mspr:pro></ContentProtection> <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed"></ContentProtection> <SegmentTemplate timescale="10000000" presentationTimeOffset="0" media="$RepresentationID$_Segment-$Time$.m4a" initialization="$RepresentationID$_init.m4i"> <SegmentTimeline> <S t="260148240443050" d="40000000" r="14" /> </SegmentTimeline> </SegmentTemplate> <Representation audioSamplingRate="32000" codecs="mp4a.40.2" id="1697609122858item-05item" bandwidth="64000" /> </AdaptationSet> <AdaptationSet mimeType="audio/mp4" startWithSAP="1" lang="ch2" segmentAlignment="true"> <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc"></ContentProtection> <ContentProtection schemeIdUri="urn:uuid:9a04f079-9840-4286-ab92-e65be0885f95"><mspr:pro xmlns:mspr="urn:microsoft:playready">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</mspr:pro></ContentProtection> <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed"></ContentProtection> <SegmentTemplate timescale="10000000" presentationTimeOffset="0" media="$RepresentationID$_Segment-$Time$.m4a" initialization="$RepresentationID$_init.m4i"> <SegmentTimeline> <S t="260148240443050" d="40000000" r="14" /> </SegmentTimeline> </SegmentTemplate> <Representation audioSamplingRate="32000" codecs="mp4a.40.2" id="1697609122858item-06item" bandwidth="64000" /> </AdaptationSet> <AdaptationSet mimeType="audio/mp4" startWithSAP="1" lang="ch3" segmentAlignment="true"> <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc"></ContentProtection> <ContentProtection schemeIdUri="urn:uuid:9a04f079-9840-4286-ab92-e65be0885f95"><mspr:pro xmlns:mspr="urn:microsoft:playready">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</mspr:pro></ContentProtection> <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed"></ContentProtection> <SegmentTemplate timescale="10000000" presentationTimeOffset="0" media="$RepresentationID$_Segment-$Time$.m4a" initialization="$RepresentationID$_init.m4i"> <SegmentTimeline> <S t="260148240443050" d="40000000" r="14" /> </SegmentTimeline> </SegmentTemplate> <Representation audioSamplingRate="32000" codecs="mp4a.40.2" id="1697609122858item-07item" bandwidth="64000" /> </AdaptationSet> <AdaptationSet mimeType="audio/mp4" startWithSAP="1" lang="ch4" segmentAlignment="true"> <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc"></ContentProtection> <ContentProtection schemeIdUri="urn:uuid:9a04f079-9840-4286-ab92-e65be0885f95"><mspr:pro xmlns:mspr="urn:microsoft:playready">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</mspr:pro></ContentProtection> <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed"></ContentProtection> <SegmentTemplate timescale="10000000" presentationTimeOffset="0" media="$RepresentationID$_Segment-$Time$.m4a" initialization="$RepresentationID$_init.m4i"> <SegmentTimeline> <S t="260148240443050" d="40000000" r="14" /> </SegmentTimeline> </SegmentTemplate> <Representation audioSamplingRate="32000" codecs="mp4a.40.2" id="1697609122858item-08item" bandwidth="64000" /> </AdaptationSet> </Period> </MPD> root@VM-E0x8qW1r1DvE:~Last edited by shy0o; 14th Aug 2024 at 04:55.
Thanks.
The presence of the <ContentProtection> element with the Widevine UUID indicates the use of Widevine DRM, but the lack of additional information suggests that the playback environment is expected to handle the specifics of the license acquisition and decryption process.
The missing references could mean that the actual decryption and playback of the content require external configuration or that the player handling the MPD file already has the necessary information to acquire the license (e.g., pre-configured license server URLs or pre-shared keys).
AllHell3Gui and clan cannot work without one of the missing references - of which there are three; pssh, Default_KID and parsing for pssh in init.m4f (1st video segment)
I asked chatgpt whether the schema follows google Widevine recommendations. It replied:
So since it isn't widevine compliant I disregard this result.No, the <ContentProtection> schema you provided does not fully follow Google Widevine's recommendations. While the schemeIdUri correctly identifies the content as being protected by Widevine, a compliant Widevine MPD typically includes additional elements and data to meet the full requirements of Widevine DRM.
Key Elements Typically Included:
PSSH (Protection System Specific Header):
Widevine DRM generally requires a cenc
ssh element within the <ContentProtection> element. The pssh (Protection System Specific Header) is a Base64-encoded binary blob that contains necessary initialization data for the DRM system. This data is used by the player to request the decryption keys from the license server.
Example:
xml
<ContentProtection
cenc
ssh="Base64 encoded pssh data">
License Acquisition URL (Optional but Recommended):
While not mandatory in the MPD file, it is often helpful to include a widevine:license element or similar, which provides the license acquisition URL. This helps players to know where to send their license requests without needing external configuration.
Content Protection Attributes:
Widevine may also require certain attributes like cenc:default_KID (Key Identifier) to be included in the MPD for more precise control over the DRM process.
Why Full Compliance Matters:
Player Compatibility: Without the pssh data, many players that expect it might not be able to request the necessary license, leading to playback failure.
Security and Efficiency: Widevine's recommended structure ensures that all necessary data for content decryption is provided directly in the MPD, streamlining the process and ensuring a higher level of security.
Conclusion:
The example <ContentProtection> element you provided does indicate Widevine protection, but it does not include the full set of information recommended by Google Widevine for DRM-protected content. For full compliance and optimal playback support, the MPD should include the pssh data and possibly other elements like the license URL or default KID.Last edited by A_n_g_e_l_a; 14th Aug 2024 at 05:29.
[Release] CDRM-Project 2.0
By TPD94 in forum Video Streaming DownloadingReplies: 38Last Post: 15th Oct 2025, 08:23 -
N_m3u8DL-RE pre-release
By stabbedbybrick in forum Video Streaming DownloadingReplies: 10Last Post: 10th May 2024, 16:37 -
Northern Exposure, Fabulous release
By mylarkee in forum Blu-ray RippingReplies: 0Last Post: 6th Mar 2024, 12:42 -
New Release! DVDFab Downloader All-In-One
By DVDFab Staff in forum Video Streaming DownloadingReplies: 0Last Post: 18th Jan 2021, 01:49 -
New Release!!!DVDFab v11.0.8.6 is out!
By DVDFab Staff in forum Latest Video NewsReplies: 0Last Post: 13th May 2020, 23:59
