I have an mkv file I would like to fade in and out without re-encoding or making any other edits. Is there a freeware that can do this? Thanks
Fade ins and outs actually changes the pixel data, so you will *ALWAYS* have to re-encode (unless you used some specialty playlist software that did it for playback which hasn't been created yet).
Doesn't matter if it's freeware or not, GUI or CLI.
Scott -
Cut a short bit from the beginning and end and re-encode them to fade in and out and then append them back to the main video.
Can I fade in\out using AudioTrim?
By smike in forum EditingReplies: 1Last Post: 12th Jun 2024, 14:22 -
ffmpeg fade out beginning & end of video without re-encoding middle part ?
By DonSeenu in forum Video ConversionReplies: 4Last Post: 28th Sep 2021, 04:00 -
How to fade in/out
By JackTenSuited in forum Newbie / General discussionsReplies: 3Last Post: 6th May 2021, 10:38 -
Fade in/Fade out, remove beginning or ending, invert
By Shinnen in forum Newbie / General discussionsReplies: 3Last Post: 22nd Mar 2021, 19:38 -
VSDC - Sprite fade out
By helioshimojo in forum Newbie / General discussionsReplies: 2Last Post: 11th Feb 2020, 21:59
