  1. I'm a Super Moderator johns0's Avatar
    canada
    Just updated thunderbird 64 today and found it has this message in the incoming screen for messages,anyone find a way to remove it?Don't need to be told there are no messages.
    Feb 2006
    try to delete the global-messages-db.sqlite file - https://support.mozilla.org/gu-IN/questions/1154563
  3. I'm a Super Moderator johns0's Avatar
    canada
    This is an update from thunderbird that is permanent.
    Feb 2006
    perhaps try reinstall thunderbird ??
    canada
    Already tried that,it's a change that thunderbird did,gonna have to wait awhile,just wanted to get rid of that message.
  6. Adding the following lines to my Thunderbird userChrome.css did the trick for me. Hope this works for you too.
    /* Hide "No message found" for empty folders */
    #placeholderNoMessages {
    display: none;
    canada
    Didn't work for me.
  8. I'm a Super Moderator johns0's Avatar
    canada
    Thanks for the tips and help,it worked after enabling userchrome.css.
