https://www.videohelp.com/software/madVR/old-versions#download
With v205 the afflicted video plays perfectly but with v206 every other frame is solid white.
Windows 10, MPC-BE
Code:General Complete name : J:\JDownloader\video (1080p aac)\video.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/iso2/avc1/mp41) File size : 1.04 GiB Duration : 1 h 41 min Overall bit rate : 1 470 kb/s Frame rate : 24.000 FPS Writing application : Lavf58.39.101 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference fra : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 1 h 41 min Bit rate : 1 221 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 24.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.055 Stream size : 887 MiB (83%) Writing library : x264 core 164 r3098 7628a56 Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=4 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=60 / keyint_min=6 / scenecut=0 / intra_refresh=0 / rc_lookahead=20 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=4060 / vbv_bufsize=5600 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00 Codec configuration box : avcC Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 1 h 41 min Bit rate mode : Constant Bit rate : 242 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Stream size : 176 MiB (16%) Default : Yes Alternate group : 1
How to reverse 3D full frame?
By tommy2010 in forum Video ConversionReplies: 40Last Post: 28th Dec 2023, 15:32 -
Mp4Box - Output is generated without frame Width, frame height & frame rate
By Saptarshi in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2022, 08:27 -
Is a full frame TBC necessary if I'm not getting dropped frames?
By nightowl3090 in forum Capturing and VCRReplies: 16Last Post: 4th Oct 2022, 18:02 -
Cannot view full frame video through USB in Sony Bravia EX 400
By shrikant.tillu in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2021, 05:08 -
Green flicker (hue) every alternative frame
By ColourMyPast in forum RestorationReplies: 4Last Post: 4th Feb 2021, 20:41
