Closed Thread
Results 1 to 19 of 19
  1. I would like to download the table tennis matches from the Olympics, have read 1080p uses L1.
    Is here anybody that can help me with? If not 720p is fine also, which uses L3.
    Thank you!
    Mar 2006
    Thank you!
    From where?
    You may have better luck with NBColympics.com, or whatever other countries streams.
  3. I actually managed to get 720p. Can anybody help me find L1 so I can get 1080p?
  4. Url?
    discord=notaghost9997
    Mar 2006
    If a true 1080p is what you want, HBO without L1 will not work.
    you can get 1080p from NBC, 9now, depending on what country you live in, VPN you use.
    etc. etc.....
  6. https://play.max.com/sport/olympic/30af269c-2209-5de3-b57b-f69d51418ff4
    2024-07-31 22:43:00 [I] MAX : > All Tracks:
    2024-07-31 22:43:00 [I] Tracks : 8 Video Tracks:
    2024-07-31 22:43:00 [I] Tracks : ├─ VID | [H.264, SDR] | 1280x720 @ 3503 kb/s, 25.000 FPS
    2024-07-31 22:43:00 [I] Tracks : ├─ VID | [H.264, SDR] | 1024x576 @ 2583 kb/s, 25.000 FPS
    2024-07-31 22:43:00 [I] Tracks : ├─ VID | [H.264, SDR] | 800x450 @ 1817 kb/s, 25.000 FPS
    2024-07-31 22:43:00 [I] Tracks : ├─ VID | [H.264, SDR] | 640x360 @ 1229 kb/s, 25.000 FPS
    2024-07-31 22:43:00 [I] Tracks : ├─ VID | [H.264, SDR] | 512x288 @ 820 kb/s, 25.000 FPS
    2024-07-31 22:43:00 [I] Tracks : ├─ VID | [H.264, SDR] | 352x198 @ 539 kb/s, 25.000 FPS
    2024-07-31 22:43:00 [I] Tracks : ├─ VID | [H.264, SDR] | 320x180 @ 335 kb/s, 25.000 FPS
    2024-07-31 22:43:00 [I] Tracks : ├─ VID | [H.264, SDR] | 320x180 @ 233 kb/s, 25.000 FPS
    2024-07-31 22:43:00 [I] Tracks : 25 Audio Tracks:
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | zxx | [Original]
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | en
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | de
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | fr
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | sv
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | fi
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | da
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | no
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | it
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | tr
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | es
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | pt-PT | European
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | nl
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | pl
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | ru
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | ro
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | el
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | sr
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | hu
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | cs
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | bg
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | ekk
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | hi
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | sl
    2024-07-31 22:43:00 [I] Tracks : ├─ AUD | [AAC] | [mp4a] | 77 kb/s | lvs
    2024-07-31 22:43:00 [E] MAX : - There's no 1080p resolution video track. Aborting.
  7. I have tried for Table Tennis and it has
    https://play.max.com/sport/olympic/0011543a-a8ef-5211-9ab1-9aaed10054be
    00:19:07.004 INFO : Vid *CENC 1920x1080 | 9429 Kbps | avc-sdr-1080p-50fps-92000kbps | avc1.64002a | 3240 Segments | ~02h52m48s
    Problem is after decrypt the video is corrupted, I guess it's the keys since it works fine with 720p.
  8. Compare the Key ID with the Key ID inside the PSSH of the 1080p manifest. This tool could come in handy.
    Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
  9. 01056d72794ea34c3a155d75b96e1c3e:7180f79d5535d2f12 7268692f90e60a0
    https://gofile.io/d/UyFi2o
  10. https://paste.linux.chat/?b7d0f3eb72b0b818#7BADF3WdoAqBwR4dzj294Z5gNC63GLdJN2hB8M9J4bev
    I've decoded the PSSH, the small one that's the same for all tracks, it contains all "cenc:default_KID" including the one from the 1080p.
  11. What is the difference between Key ID and content ID from the PSSH? Is it the key to get 1080p?
    [Attachment 81102 - Click to enlarge]
  12. Both can be used to identify the key that is needed. It's just interesting that both are being used at the same time (because they shouldn't).
  13. Everytime I download a video from Max (sport replay, movie or programme) using N_m3u8DL-RE with the obtained keys, the audio is ok but the video is corrupted.
    When muxing it shows errors like "top block unavailable for requested intra mode -1", "error while decoding MB 1 0, bytestream 4867", "left block unavailable for requested intra4x4 mode -1".
    What am I doing wrong?
    Thanks in advance.
  14. Originally Posted by Chopenjauer View Post
    Thanks in advance.
    https://forum.videohelp.com/threads/404993-Please-ONLY-ask-for-help-videos-that-everyo...ere-is-my-post
  15. Originally Posted by Sawyer View Post
    Thank you!
    Did you find a solution?
  16. Only for 720p.
    Aug 2024
    France
    Only for 720p.
    Hi,
    Can you provide help to get the 720p please ?
  18. Originally Posted by jul2003 View Post
    Only for 720p.
    Hi,
    Ask someone via pm or follow this https://forum.videohelp.com/threads/404993-Please-ONLY-ask-for-help-videos-that-everyo...ere-is-my-post
  19. I'm a MEGA Super Moderator Baldrick's Avatar
    Max is not a free streaming service.
