  1. Just want to let you all know that I am a really noobie at this so please bear with me on this.
    Here is my problem..I just burned Starwars Episode IV from DVD to my hard drive I follwed Sefy's guide etc.
    The picture quality turned out great but the sound is a little off..I hear the constant starwars theme playing in the background and then the odd voice will appear too.. but I dont hear eveything all the characters are saying... like dart vader you can hear him breath from time to time but no voices. and no sounds of the guns etc.
    Please help on this one if you can.
    Really Appreciate this..
    ScOOt3r!
  2. Originally Posted by ScOOt3r
    only the first episode of star wars has been authorized for DVD...you must have a bootleg copy..sometimes those are very poorly authored
    anywayz, back to your problem...did you play the actual DVD and listen to the audio...did any of these problems show up when playing the actual DVD?
    if not, load the vob files in dvd2avi and preview it (f5)...post wut dvd2avi's info box sez about the audio....
    also, wut audio settings are you using in dvd2avi...your problem description was kinda vague..so more info is good
  3. Ok... just to let you know this dvd is the original got a friend who brought it over and has purchased it overseas, (but besides that this is the orginal, his uncle works for LucasARts too :) (I have the whole trilogy here).
    ok here are my setting in DVD2AVI
    Audio: Track 1
    Channel Format: Autoselect
    Dolby Digitial: DEcodec, Mp3 audio: Demux
    48x44: off
    Video Settings:
    Idct AGlorithym: 33\2 bit sse mmx
    Field Operation: force film
    and the rest are default.
    I also got my 2 files: D2V & WAVE FILE.
    D2V is about: is 637K
    while my audio is about: 1,418,647kb
    Video:
    Aspect Ratio 4:3, Frame Type: 23.976 fps, Video Type: Interlaced, VOB Cell ID: 1, 2
    Audio:
    Format: DD 3/2 448,
    Avi: Nothing in here
    Status: Finished
    And Yes I did play the Original DVD.. sound is great and works fine.
    Ok please let me know what you think.. I have followed the instructions exactly but I dont see any thing different.
    ScOOter
  4. Originally Posted by ScOOt3r
    just to let you know....since the video type is INTERLACED, you need to turn force film off in dvd2avi and use the NTSC template (not NTSC FILM template)
    Audio:
    Format: DD 3/2 448,
    doesn't seem like there's anything wrong here...did you play the .wav file after u extracted it w/ dvd2avi? was there anything wrong with it? if there was, you can try another track to extract...
    otherwise, if the .wav file is good, then in tmpgenc config options, make sure your sampling frequency is 44.1 khtz (need to downsample for some dvd players), channel mode is stero, and bitrate is 224 kbit/s
