iam using StaxRip-v2.29.0 and it works fine but sometimes i had this problem for many videos
any help plsCode:------------------------- System Environment ------------------------- StaxRip : v2.29.0 Windows : Windows 10 Pro 22H2 2009 (19041.1.amd64fre.vb_release.191206-1406) Language : English (United States) CPU : Intel(R) Xeon(R) CPU E3-1230 v5 @ 3.40GHz RAM : 8GB GPU : AMD FirePro W2100 Resolution : 1920 x 1080 DPI : 96 Code Page : 1256 ---------------------------- Configuration ---------------------------- Template : 1137 Video Encoder : x265Enc Video Encoder Profile : x265 Container/Muxer Profile : MKV (mkvmerge) --------------------------- AviSynth Script --------------------------- AddAutoloadDir("E:\Test\StaxRip-v2.29.0-x64\Apps\FrameServer\AviSynth\plugins") LoadPlugin("E:\Test\StaxRip-v2.29.0-x64\Apps\Plugins\Dual\ffms2\ffms2.dll") LoadPlugin("E:\Test\StaxRip-v2.29.0-x64\Apps\Plugins\AVS\xy-VSFilter\VSFilter.dll") tcFile = "C:\00\Ep01_temp\Ep01_timestamps.txt" # timestamps file path Exist(tcFile) ? FFVideoSource("C:\00\Ep01.mkv", cachefile="C:\00\Ep01_temp\temp.ffindex", timecodes=tcFile) : FFVideoSource("C:\00\Ep01.mkv", cachefile="C:\00\Ep01_temp\temp.ffindex") Crop(222, 0, -222, -0) TextSub("E:\Rights.ass") BicubicResize(1280, 936) ------------------------- Source Script Info ------------------------- Width : 1920 Height : 1080 Frames : 61736 Time : 41:09.440 Framerate : 25 (25/1) Format : YUV420P8 ------------------------- Target Script Info ------------------------- Width : 1280 Height : 936 Frames : 61736 Time : 41:09.440 Framerate : 25 (25/1) Format : YUV420P8 ---------------------- Media Info Audio Source 1 ---------------------- General Complete name : C:\00\Ep01_temp\ID1 9ms.aac Format : ADTS Format/Info : Audio Data Transport Stream File size : 57.3 MiB Overall bit rate mode : Variable Audio Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Format version : Version 4 Codec ID : 2 Bit rate mode : Variable Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Stream size : 57.3 MiB (100%) ------------------------ Error Video encoding ------------------------ Video encoding returned exit code: 4 (0x4) --------------------------- Video encoding --------------------------- x265 3.5+147+17-e8947f740-.Mod-by-Patman.-x64-avx2-msvc1937 E:\Test\StaxRip-v2.29.0-x64\Apps\Support\avs2pipemod\avs2pipemod64.exe -dll=E:\Test\StaxRip-v2.29.0-x64\Apps\FrameServer\AviSynth\AviSynth.dll -y4mp C:\00\Ep01_temp\Ep01_new.avs | E:\Test\StaxRip-v2.29.0-x64\Apps\Encoders\x265\x265.exe --frames 61736 --bitrate 850 --output-depth 10 --level-idc 3.1 --high-tier --rd 4 --rdoq-level 2 --limit-refs 1 --refine-mv 1 --b-intra --limit-modes --aq-mode 3 --crf-max 0 --vbv-bufsize 7500 --vbv-maxrate 8000 --subme 5 --me umh --merange 35 --max-merge 3 --rc-lookahead 25 --lookahead-slices 0 --lookahead-threads 5 --scenecut-bias 0.05 --min-keyint 24 --keyint 240 --no-open-gop --pools 32 --log-level 2 --colorprim bt2020 --colormatrix bt2020c --transfer bt1361e --range limited --max-luma 1023 --no-cll --videoformat mac --repeat-headers --aud --hrd --input-csp i400 --deblock -1:-1 --no-strong-intra-smoothing --y4m --output C:\00\Ep01_temp\Ep01_new_out.hevc - avs2pipemod[info]: writing 61736 frames of 25/1 fps, 1280x936, sar 0:0, YUV-420-planar-8bit progressive video. y4m [INFO]: 1280x936 fps 25/1 i420p8 unknown frame count raw [INFO]: output file: "C:\00\Ep01_temp\Ep01_new_out.hevc" x265 [INFO]: HEVC encoder version 3.5+147+17-e8947f740 [Mod by Patman] x265 [INFO]: build info [Windows][MSVC 1937][64 bit] 10bit x265 [INFO]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 x265 [FLAW]: picture dimensions are out of range for specified level x265 [FLAW]: x265_encoder_open() failed for Enc, aborted at input frame 1, output frame 0 in x265 avs2pipemod[info]: finished, wrote 3 frames [0%]. avs2pipemod[info]: total elapsed time is 0.193 sec. avs2pipemod[error]: only wrote 3 of 61736 frames. --------------------------- Video encoding --------------------------- x265 3.5+147+17-e8947f740-.Mod-by-Patman.-x64-avx2-msvc1937 E:\Test\StaxRip-v2.29.0-x64\Apps\Support\avs2pipemod\avs2pipemod64.exe -dll=E:\Test\StaxRip-v2.29.0-x64\Apps\FrameServer\AviSynth\AviSynth.dll -y4mp C:\00\Ep01_temp\Ep01_new.avs | E:\Test\StaxRip-v2.29.0-x64\Apps\Encoders\x265\x265.exe --frames 61736 --bitrate 850 --output-depth 10 --level-idc 3.1 --high-tier --rd 4 --rdoq-level 2 --limit-refs 1 --refine-mv 1 --b-intra --limit-modes --aq-mode 3 --crf-max 0 --vbv-bufsize 7500 --vbv-maxrate 8000 --subme 5 --me umh --merange 35 --max-merge 3 --rc-lookahead 25 --lookahead-slices 0 --lookahead-threads 5 --scenecut-bias 0.05 --min-keyint 24 --keyint 240 --no-open-gop --pools 32 --log-level 2 --colorprim bt2020 --colormatrix bt2020c --transfer bt1361e --range limited --max-luma 1023 --no-cll --videoformat mac --repeat-headers --aud --hrd --input-csp i400 --deblock -1:-1 --no-strong-intra-smoothing --y4m --output C:\00\Ep01_temp\Ep01_new_out.hevc - avs2pipemod[info]: writing 61736 frames of 25/1 fps, 1280x936, sar 0:0, YUV-420-planar-8bit progressive video. y4m [INFO]: 1280x936 fps 25/1 i420p8 unknown frame count raw [INFO]: output file: "C:\00\Ep01_temp\Ep01_new_out.hevc" x265 [INFO]: HEVC encoder version 3.5+147+17-e8947f740 [Mod by Patman] x265 [INFO]: build info [Windows][MSVC 1937][64 bit] 10bit x265 [INFO]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 x265 [FLAW]: picture dimensions are out of range for specified level x265 [FLAW]: x265_encoder_open() failed for Enc, aborted at input frame 1, output frame 0 in x265 avs2pipemod[info]: finished, wrote 3 frames [0%]. avs2pipemod[info]: total elapsed time is 0.193 sec. avs2pipemod[error]: only wrote 3 of 61736 frames. Start: 1:20:58 AM End: 1:20:58 AM Duration: 00:00:00 ----------------------------- Find Gain 1 ----------------------------- ffmpeg N-111918-g0adaa90d89-x64-gcc13.2.0 E:\Test\StaxRip-v2.29.0-x64\Apps\FrameServer\AviSynth\ffmpeg.exe -i "C:\00\Ep01_temp\ID1 9ms.aac" -sn -vn -hide_banner -af volumedetect -f null NUL [aac @ 0000017a2c688ec0] Estimating duration from bitrate, this may be inaccurate Input #0, aac, from 'C:\00\Ep01_temp\ID1 9ms.aac': Duration: 00:40:52.67, bitrate: 195 kb/s Stream #0:0: Audio: aac (LC), 48000 Hz, stereo, fltp, 195 kb/s [Parsed_volumedetect_0 @ 0000017a2deeee80] n_samples: 0 Stream mapping: Stream #0:0 -> #0:0 (aac (native) -> pcm_s16le (native)) Press [q] to stop, [?] for help Output #0, null, to 'NUL': Metadata: encoder : Lavf60.11.100 Stream #0:0: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s Metadata: encoder : Lavc60.25.100 pcm_s16le Start: 1:20:58 AM End: 1:20:58 AM Duration: 00:00:00
Doing a Remux, mkvtoolnix exit code 2
By maudit in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jul 2022, 09:26 -
encoding by staxrip H264 without GPU
By ALMGHARI in forum Video ConversionReplies: 5Last Post: 27th Nov 2019, 07:10 -
Staxrip "Jerky Playback" After Encoding a Video
By deepfrayder in forum Newbie / General discussionsReplies: 19Last Post: 11th Nov 2019, 23:50 -
Staxrip Encoding Issue
By deepfrayder in forum Video ConversionReplies: 12Last Post: 1st Nov 2019, 02:10 -
Is there a code for santiag in Staxrip with avisinth+ ?
By SomeoneNeutral in forum RestorationReplies: 4Last Post: 4th Sep 2019, 12:11
