Hi all!
How could I capture following stream:
https://plus.rtl.de/video-tv/shows/stern-tv-791695/2024-7-1006198/episode-28-sendung-v...4072024-970336
Any help was great!
Greetings,
HJ
Results 1 to 10 of 10
Example for a recording of 2 minutesCode:
N_m3u8DL-RE --key 3c65a53ab54b09f696ce477e7b5b6f80:b1210cae3b0e64f9821e66100a24f971 --live-real-time-merge --live-record-limit 00:02:00 "https://vodnowusoawsdash-cf.tvnow.de/p112/cves/sd/rtlplus/970336/3-1-1-3-2.ism/v1.mpd" -M format=mp4
Hi all!
Downloading from both files are running,but through the muxing process coming an error:
06:49:09.451 WARN : Reading media info...
06:49:09.476 INFO : NaN: Video, h264 (avc3), 1920x1080
06:50:01.352 INFO : Binary merging...
06:50:38.282 INFO : Decrypting...
06:50:38.837 INFO : Start downloading...Aud audio_1=128000 | 128 Kbps | mp4a.40.2 | de | 2CH
06:50:39.466 WARN : Type: cenc
06:50:39.467 WARN : PSSH(WV): CAESIDNjNjVhNTNhYjU0YjA5ZjY5NmNlNDc3ZTdiNWI2ZjgwIg Y5NzAzMzYqAlNE
06:50:39.469 WARN : KID: 3c65a53ab54b09f696ce477e7b5b6f80
06:50:39.470 WARN : Reading media info...
06:50:39.938 INFO : NaN: Audio, aac (mp4a), 128 kb/s
06:50:55.692 INFO : Binary merging...
06:50:55.814 INFO : Decrypting...
06:50:55.966 WARN : v1_2024-07-30_06-49-06.mp4
06:50:55.967 WARN : v1_2024-07-30_06-49-06.de.m4a
06:50:55.967 WARN : Muxing to v1_2024-07-30_06-49-06.MUX.mp4
06:50:56.372 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 000001a4c746b300] Incorrect number of samples in encryption info
06:50:56.372 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 000001a4c746b300] Could not find codec parameters for stream 0 (Video:
h264 (avc3 / 0x33637661), none, 1920x1080, 7789 kb/s): unspecified pixel format
06:50:56.374 WARN : Consider increasing the value for the 'analyzeduration' and 'probesize' options
06:50:56.499 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 000001a4d0807300] Incorrect number of samples in encryption info
06:50:56.502 WARN : [mp4 @ 000001a4d7208640] track 1: codec frame size is not set
06:50:56.504 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 000001a4d0807300] Incorrect number of samples in encryption info
06:50:56.504 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 000001a4c746b300] Incorrect number of samples in encryption info
06:50:56.505 WARN : C:\Users\Hans J├Ārg\v1_2024-07-30_06-49-06.mp4: Invalid data found when processing input
06:50:56.505 WARN : C:\Users\Hans J├Ārg\v1_2024-07-30_06-49-06.de.m4a: Invalid data found when processing input
06:50:56.617 WARN : Cleaning files...
06:50:56.803 WARN : Rename to v1_2024-07-30_06-49-06.mp4
06:50:56.804 INFO : Done
Size is only 1kb after muxing
What is wrong?
Greetings,
HJ -
The command works
[Attachment 81046 - Click to enlarge]
Check that you have mp4decrypt and ffmpeg in the same folder as N_m3u8DL-RE
[Attachment 81047 - Click to enlarge] -
Hi all!
I got an older ffmeg version number from 2019!
Which version I need?
A link possible,using Windows!
Greetings,
HJ -
Hi all!
I could download and muxing now the video,but i got a lot of pixels through the video!
Any help?
Greetings,
HJ -
Try with the last version of ffmpeg....
https://github.com/BtbN/FFmpeg-Builds/releases
If you got a lot of Pixels, your video is not decrypted....
The key I give you is the good one....The problem comes from mp4decrypt.
https://www.bento4.com/downloads/ -
Hi!
On Bento I couldn't found a mp4 decrypt download folder!
Is there another platform for grab these?
Greetings,
HJ -
Hi all!
Always the same problem,I couldn't decrypt the file!
Here a screenshot of my folder:
[Attachment 81052 - Click to enlarge]
Any idea?
Greetings,
HJ
Help with stream capture
By themusicman in forum Video Streaming DownloadingReplies: 8Last Post: 15th Sep 2024, 10:42 -
BBC Glastonbury Live Stream Capture
By ghostrewel in forum Video Streaming DownloadingReplies: 9Last Post: 16th Jun 2024, 09:10 -
How to capture this live stream.
By pedrothelion in forum Video Streaming DownloadingReplies: 4Last Post: 4th Jul 2021, 12:18 -
how to capture rtmp stream on android?
By Silv3r in forum Video Streaming DownloadingReplies: 4Last Post: 22nd Nov 2020, 12:17 -
Using VLC to stream a capture card so that it can be watched elsewhere...
By gdogg371 in forum Newbie / General discussionsReplies: 0Last Post: 5th Jan 2020, 14:29
