Closed Thread
  1. This website doesn't even allow you to press f12 on the page.
    https://coivl.n/zmxjmr
    Any idea how to get the m3u8 links?
  2. Member aqzs's Avatar
    Mar 2024
    Paris
    I have made a custom python script. Here are the download commands for your show :
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/133a83628d277d2d6d4550602171aa00/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.1"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/4ce05e0a5a7921ce77329c6b193f76e2/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.2"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/466642463b08f3da3c98c37cd33e1d0b/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.3"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/6fcc5f828dba1326b539af2e325f07c0/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.4"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/4f7365c4764c385bfddeffa80f74de3c/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.5"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/b5192d322d6b11a3b6948b71ea7b20b1/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.6"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/2ef1fbd2a57bc522507d87a0e585ea71/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.7"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/f7477295a4ebc757e55b7842afe222bb/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.8"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/b32c285efdf29c738c638b32080a5a09/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.9"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/4ce5e8515451dea660be3ef086be4dbf/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.10"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/650e65297af73bbe7ca76971e25300f3/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.11"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/2bf416239b585e2f53a00c7215bebd9b/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.12"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/18835395073d1882b5f17e24f5a2478e/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.13"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/5dd6d2f9853473700ed1f35e0be5e892/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.14"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/a00628f619edb993d3f19cc8b045a164/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.15"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/ced247a8b27646956a5220c52078b467/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.16"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/8de9491808d4003c6df71bc7b4d51bb6/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.17"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/623d0e2f33b0c43758a7bf783a8366e4/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.18"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/98bec265c878b62080c82765462d7d43/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.19"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/c91535bd0e099113b108c4bb8c4b9ace/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.20"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/759f82ed5f7ca7da56c6a9a12411e110/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.21"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/51d61e95c3ec28caa5115ef2c5d3ce23/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.22"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/2cea905d70ae314411479eb36a99854a/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.23"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/ad3a9e14d63459e630c4c764d6f6a1e2/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.24"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/cc4cd09ebf0d8e196038fd0a6fc5fc7d/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.25"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/43af8924ecd45fb0faa42420850c40d2/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.26"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/bdca23650b1ff3326132f41e2917e400/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.27"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/ff9278d9bde09ceb78b18fb74afa20cd/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.28"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/b7def60f0fc3b004f6e84ebf0e9fb052/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.29"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/a951ef533ca74e975c938d09202976c6/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.30"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/64a70ee70e3526738aa247afda897ac9/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.31"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/fceb7a9b27b3c2f8995d55465a6ba7f8/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.32"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/2a1819e5843172ef70e1ce88ae090c75/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.33"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/fb8534b090a8e78a53eba103d4067ee1/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.34"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/285fe295970230a0098222e46ac3d100/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.35"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/1c0cb6318b3f7596c2e7a8a2d4eb1cda/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.36"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/aaa08b6395e1d141f7e9fe6af5285d7a/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.37"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/3ddbc04e651453840aa11ce72488796d/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.38"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/8fb4274b17841824017725f780656e8c/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.39"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/580c4f9698dc23867ddf4e14a27077a2/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.40"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/b381c2088b38ca6ba335578e618d9352/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.41"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/9a4e89e2e24f249e29a21c60cb52bfee/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.42"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/50398a698e54cd4bcfaa931e1f9c56c0/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.43"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/913bb3843d311f265d17e0bb35a4bd67/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.44"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/a111f99c8624828a13a442a49b0115e4/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.45"
    N_m3u8DL-RE "https://vietnoiket.com/cdn/hls/4144cb73fcf78dcc3089d48a9e3f5dbf/master.txt" -H 'accept: */*' --save-name "Khanh.Du.Nien.Tap.46.End"
  3. Originally Posted by aqzs View Post
    Thank you so much!
    Please do not link to warez streaming linking sites.
