hello
if im recording live stream with VLC media player , and video source is 1080p can i record directly in 720p? anyway to change video resolution?
Results 1 to 13 of 13
It's definitely possible, OBS can do it.
Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2 -
It's a setting
[Attachment 80969 - Click to enlarge]Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2 -
You told me to explain, so I did.
Anyways I don't use VLC, I use mpv, so I can't help you with that.Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2 -
Downscaling requires a reencoding, which your machine probably can't do in real time for 720p if you don't have a video card.
Probably your m3u8 playlist already proposes a 720p stream; why don't you simply download that one? -
yt-dlp "https://80-251-153-55.servers.party:5052/live23/PwErRwRP05omAGC0OnYIgQ/1149764/1722004208/3021105.m3u8"
[generic] Extracting URL: https://80-251-153-55.servers.party:5052/live23/PwErRwRP05omAGC0OnYIgQ/1149764/1722004...8/3021105.m3u8
[generic] 3021105: Downloading webpage
ERROR: [generic] Unable to download webpage: HTTP Error 403: Forbidden (caused by <HTTPError 403: Forbidden>)
Convert rec.601 into rec.709?
By killerteengohan in forum RestorationReplies: 8Last Post: 15th Jun 2021, 19:25 -
I just captured VHS with a Rec 709 colors space instead of Rec 601.
By jpvoodoo in forum Capturing and VCRReplies: 4Last Post: 25th Apr 2021, 12:42 -
Change Playlist Fonts In VLC
By cdycus in forum Newbie / General discussionsReplies: 0Last Post: 1st Oct 2020, 07:59 -
Converting rec.709 to rec.601?
By killerteengohan in forum RestorationReplies: 22Last Post: 13th Jun 2020, 17:19 -
how to remove the exactly string colorMatrix(mode="Rec.601->Rec.709") ?
By marcorocchini in forum Newbie / General discussionsReplies: 16Last Post: 11th Aug 2019, 00:40
