Hello, I have several videos that I need to encode, these videos have different size and I wish to encode in a small size but keeping amazing quality, so I need to know the final biltrate or how can I do it? thank you in advance!
You can't know. Each video requires a different bitrate. And what you consider "amazing quality" may not be the same thing someone else finds as amazing. Different codecs will required different bitrates. And the codec settings you use (for example fast vs slow encoding) will require different bitrates.
You can run multiple encodes until you find what you like. Or you can use an encoder with "quality" based encoding. You select the quality you want and the encoder uses whatever bitrate is necessary to deliver that quality.
Concatenating while encoding clips from video A without encoding video B
By imkira3 in forum EditingReplies: 10Last Post: 9th Jun 2024, 07:24 -
Video encoding.
By Epona46 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Feb 2023, 14:55 -
Please help with video encoding
By BlurayHD in forum Newbie / General discussionsReplies: 1Last Post: 24th Jul 2022, 12:59 -
Video Encoding
By biferi in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2022, 08:15 -
How to convert .m2ts video to .mkv video without re-encoding by ffmpeg ?
By aaajan in forum Video ConversionReplies: 13Last Post: 27th Aug 2021, 09:30
