I've purchased a used Compro VideoMate s350 DVB/TV card on eBay dating from around 2009.
My intention is to use it to capture PAL footage from Hi8 camcorders, etc.
I'm usung Windows 10, and the card was successfully detected as a VideoMate TV SAA7133/35. Hybrid Capture Device, under Sound, video and game controllers in Windows Device Manager.
The driver version is 1.3.9.1 (14/03/2011)
I can't find any newer drivers when I Google search.
Using VirtualDub 1.9.11, the only output size option in the video capture pin stream format is 320 x 240 for any of the video standards settings despite the card having an S-video input, which you would think implies 720 x 576 PAL capability.
I have another capture device, a Tevion/Kworld VS-USB2800D USB dongle which works fine with VirtualDub and captures PAL 720 x 576 no problem.
I can't find any capture specifications for this card, even in the user manual.
Has anyone out there had one of these cards and achieved higher capture resolution?
Thanks in advance
Rob
My YouTube channel with little clips: vhs-decode, comparing TBC, etc.
When in Capture mode, have a look in Video>Set custom format. Is 720/576 in that list?
[Attachment 80999 - Click to enlarge]
video capture with Compro e900f
By V_J in forum Capturing and VCRReplies: 10Last Post: 2nd Feb 2025, 14:21 -
Can I post my new themes for DVB Dream in DVB / IPTV forum?
By Dreamer in forum Newbie / General discussionsReplies: 0Last Post: 30th Jun 2024, 07:02 -
Connect old PC VGA to HDMI on TV--resolution limited to graphics card?
By gumbygum in forum DVB / IPTVReplies: 28Last Post: 10th Nov 2021, 05:21 -
Using Canon's EOS Utility to capture on screen video VS a capture card
By RoyZ7 in forum Capturing and VCRReplies: 0Last Post: 23rd Apr 2020, 08:18 -
USB TV Tuner for all Regions (ATSC, DTMB, DVB-T/DVB-T2, and ISDB-T)
By SuperLOL in forum DVB / IPTVReplies: 8Last Post: 6th Jan 2020, 21:42
