    Jul 2024
    Lisbon
    Is it possible to restream a .mpd URL + keys using N_m3u8DL-re? I've tried everything, but the .ts file that is created keeps getting infinitely large. Could you explain…
  2. you can use streamlink using this command streamlink.exe "http://.mpd " best --ffmpeg-dkey "key"
    Jul 2024
    Lisbon
    I can generate an m3u8 file with the streamlink? Thanks!
  4. python -m streamlink --ffmpeg-dkey "key" -O .mpd best | ffmpeg -nostdin -hide_banner -loglevel error -i - -c copy -f hls -hls_segment_type mpegts -hls_flags delete_segments+append_list -segment_list_flags live+program_date_time -hls_time 2 -hls_list_size 10 /var/www/hls/index.m3u8
    Same ffmpeg command for n M3u8dl re
    Or in mpegts http stream
    streamlink --player-external-http --player-external-http-port=1000 mpd best
    Edit: for Linux
    discord=notaghost9997
    Jul 2024
    Lisbon
    streamlink player-external-http --player-external-http-port=1000 mpd best
    Thanks, my friend! I tested all these commands, including with N_m3u8DL-RE, but it didn't work.
  6. Message me on discord.
    Jul 2024
    Lisbon
    I sent the request
    Jul 2024
    Lisbon
    Edit: for Linux
    Thanks, notaghost!
    It worked perfectly!
