I'm trying to keep the sharpness as high as possible using the QTGMC script with partial success. The biggest problem is actually the OSD.
1. Is it possible to keep the actual image sharp (or even make it sharper) without increasing the OSD brightness? I've tried using Sharpness=0 and sharpening with lsfplus, but lsfplus ignores the brick wall (even in edgesharpen mode).
2. There's a halo around the OSD -- is there an option that doesn't cause this?
Frame 150:
https://imgsli.com/MjgwNzY5
b2=b1.QTGMC(preset="slower",InputType=1,noiseproce ss=1,noisepreset="slower",
\ blocksize=12,search=3,searchparam=1,subpel=4,match enhance=1,Rep0=4,Rep2=4,stabilizenoise=true,source match=2,
\ TR0=2,TR1=2,TR2=3,chromanoise=true,noiserestore=0, grainrestore=0,sigma=4,sharpness=1,showsettings=fa lse).subtitle("b2")
What are you aiming for? When the OSD is sharp, some of the details in the image seem less sharp,
and details blurred away.
Why are you even running qtgmc on this source? -
QTGMC beautifully stabilizes OSD.
It also preserves sharpness best at Sharpness=1 (or destroys it the least at Sharpness=0). Unfortunately, it causes halo and brightens OSD too much.
I also tried using Sharpness=0 and sharpening in a different way, but the results were even worse.Last edited by rgr; 22nd Jul 2024 at 16:35.
OK. Wait and see if you get some further responses, this is going beyond my experience.
Have you looked at Overlay to see if you can "fix" (reduce the brightness?) the OSD after the qtgmc?
Some kind of mask that isolates that section? -
Yes, I am considering processing this image fragment with Sharpness=0, but only if all else fails.
I use sharpness 0.1. A sharpness of 0.2 is also tolerable in some situations, but anything higher than that is too much for me. The sharpener in it seems more powerful than average or is prone to halos pretty easily. If I by some miracle need anymore sharpening, I use a dedicated sharpening filter like limitedsharpenfaster.
A lot of the default settings are more destructive to detail than the average person would like. Give this a try and see how you like it.
It's possible it wont make the text look as stable since it's set for detail preservation and wont smear it, but give it a try, it just might still do it.
Code:QTGMC(preset="slow", matchpreset="slow", matchpreset2="slow", sourcematch=3, tr1=2, tr2=1, NoiseTR=2, sharpness=0.1)
Code:LimitedSharpenFaster(ss_x=1.00, ss_y=1.00, strength=7, overshoot=0, undershoot=0, soft=0, edgemode=0)
Last ditch attempt, if none of that pleases you, try a dehalo filter to lessen it.
Code:source = last dehalo_alpha(rx=1.2, ry=1.2, darkstr=0, lowsens=0, highsens=50, ss=1.0) MergeChroma(last, source)
Maybe some thing like this after generating b2:
Code:blackmask = b2.mt_binarize(50, upper=true).mt_expand().mt_expand().Blur(1.0).Blur(1.0).Blur(1.0) # a mask of very dark areas blackmask = blackmask.Crop(62,426,-392, -62).AddBorders(62,426,392,62) # limit mask to the timecode area dh = b2.dehalo_alpha(rx=1.0, ry=2.0, DarkStr=0.5, BrightStr=1.0) b2 = Overlay(b2, dh, mask=blackmask)
Qtgmc-GUI. A simple encoder for your Qtgmc scripts.
By ProWo in forum Video ConversionReplies: 17Last Post: 4th Mar 2023, 02:01 -
Excessive dark halo
By Andreselos in forum RestorationReplies: 0Last Post: 5th Jul 2022, 14:47 -
VHS Halo Reduction Help
By Dry Paint Dealer Undr in forum RestorationReplies: 0Last Post: 28th Jul 2021, 12:16 -
Remove halo/ghosting
By semel1 in forum Newbie / General discussionsReplies: 11Last Post: 15th Feb 2021, 17:50 -
Removing dark artifacts around halo's
By killerteengohan in forum RestorationReplies: 11Last Post: 28th Mar 2020, 10:46
