^^^ this.
@ spapakons: And always use 2-pass encoding for hitting the bitrate (target size) more precisely. 1-pass VBR encoding is never "accurate", given by its principle of operation. This is the same for all VBR encoders I am aware of.
Secondly, if an encoder is configured improperly (e.g. by setting a too high minimum quantizer) it may run into "saturation". Means whatever bitrate you specify it will never reach that bitrate (unless the encoder would just pad the bitrate).
With GUIs you have limited or no control over this.
Results 31 to 38 of 38
@Sharc - there is possibility to stabilize bitrate and to prevent buffer from starvation by adding noise to video (low level so it is practically invisible).
I didn't say FFMPEG cannot encode MPEG 2 video, I said that it completely ignores my bitrate setting resulting in a ridiculously small file with average bitrate of less than 3000K which is crap by MPEG 2 standards. I don't want to mess with command line FFMPEG just to make it work. Thankfully AVS2DVD and AVS Video Converter do an excellent job respecting my settings and output a perfect result every time.
You can also use the clever FFmpeg-GUI.
You can use this to specify the target size of your mpeg2 stream and it will be adhered to exactly.
Download it here: https://files.videohelp.com/u/292773/clever_ffmpeg_gui_328.zip
extract everything into a folder where you want and start the exe file.
Follow the instructions, then load your video, click main, click encode videostream, select resize or keep size, select the mpeg encoder, select the desired file size, select all other settings as desired (see attached picture for a conversion to DVD-NTSC) and click encode.
The generated m2v file will have exactly your desired target size.
[Attachment 81685 - Click to enlarge]Last edited by ProWo; 21st Aug 2024 at 07:57. Reason: typo
This worked OK, but according to MediaInfo it is CBR encoded. The same as setting minimum, average and maximum bitrate to the same value in other applications. For bitrates over 7000K, this will have negligible difference in image quality, but for long movies with bitrate less than 5000K it is not desirable, VBR is preferred. Thank you anyway.
Of course I do! That's the whole point of using VBR over CBR, to use more bitrate to fast scenes and less in slow scenes so overall image quality is better than CBR with the same bitrate. As I said over 7000K you won't notice any difference, but less than 5000K the difference is visible.
Any Vid Converter Ultimate Fit to Disc
By yotboy in forum Video ConversionReplies: 2Last Post: 21st Apr 2024, 08:27 -
Amv Conversion ffmpeg
By Bmcaps in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2023, 15:52 -
FFMPEG conversion gone very wrong
By SM1872 in forum Video ConversionReplies: 2Last Post: 22nd May 2022, 13:51 -
Generic FFMPEG for -> 720p conversion
By jglazer63 in forum Newbie / General discussionsReplies: 4Last Post: 26th Dec 2020, 16:03 -
bitrate calculator (how many minutes of video fit a disc w/aiff audio)
By willndmb in forum Authoring (Blu-ray)Replies: 5Last Post: 15th Aug 2020, 20:53
