I am running Windows XP Pro.
I spent a long time on this, narrowing down and trouble-shooting what the cause is.
Problem: after installing the HP software for HP dvd200i I discovered that streaming MPEG-1 off web-sites would not play with WMP. WMP would play MPEG-1 if I right-click, download and save-as, but if tried to play as it downloaded (streaming) then it would just sit there "connecting" and take about 95%+ according to Task Manager. I had to kill mplayer in task manager.
Solution: I found no easy solution so far... the only way I know to re-enable the streaming MPEG-1 support is to do a system restore in XP prior to installing (Uninstalling Sonic MyDVD does not fix). Then do an installation of the HP software again, but uncheck MyDVD. You cannot author Video DVD but I found Sonic to be not very great anyways... probably other software is better.
If someone finds out exactly what Sonic MyDVD 3 is doing to WMP, and possible to have Sonic installed please post... maybe it is a codec or something that it overwrites for MPEG-1! I am going to work on this more later.
I should also mention that if you want to use Nero 5.5.8.0 or greater, you have to kill the hpcdtray or it will cause Nero to hang when writing the lead-out. I use msconfig to remove it from startup - it is not needed.
Results 1 to 1 of 1
wmp win7 not playing certain mpeg1 files, gspot info included
By Rudyard in forum Software PlayingReplies: 6Last Post: 7th Jan 2011, 03:53 -
Streaming MPEG2-TS files to WMP 11 (XP)
By Penumbra in forum Video Streaming DownloadingReplies: 0Last Post: 2nd Apr 2010, 17:39 -
Shuffle play streaming links in WMP
By JohnnyOh in forum ProgrammingReplies: 0Last Post: 31st Dec 2009, 02:33 -
Optimal Settings for WMP Streaming Video
By john_doe1 in forum Video Streaming DownloadingReplies: 9Last Post: 24th Sep 2009, 19:12 -
help with HP dvd writer dvd200i
By azianese in forum DVD & Blu-ray WritersReplies: 8Last Post: 21st May 2007, 11:55
