Does anyone know some simple video editing programs that can crop properly without needing to enter the output video dimensions?
				Results 1 to 11 of 11
	Windows 10, MPC-BE
	I have that program already. I don't see a crop option anywhere. It is the least user friendly program ever. I need a visual crop where I can crop a video using a graphical border that I can resize on the video itself. Windows 10, MPC-BE
	Start the program, load your video, click main, click encode videostream, click crop detect, click preview.
 With next you do the next cropdetect 30 seconds later aso.
 Your opinion on user-friendliness probably stems from the fact that you haven't looked into it.
 The program handles the individual streams (video, audio, subtitles) separately.
 This is more precise and offers more options than editing all streams together.
 The edited streams can then simply be muxed.
	okay I found the crop settings, but there is no boundary/border to select. This appears to require manual editing of the dimension values. Windows 10, MPC-BE
	The border is set automatically (cropdetect).
 You can see the crop values on left bottom.
 Repeat the cropdetect (next button) until the values remains the same.
 Then you have found the right crop. Click ok and the correct crop values are inserted automatically into the video encode screen.
	Uh I don't understand that at all. You think that is user friendly how? And in my post I asked for a video editor where I didn't have to input the dimension values. Windows 10, MPC-BE
	There is virtualdub of course but may you could try Avidemux?
 AviDemux latest Nightly builds
 Is has a crop/mask filter you can easily adjust manually.
 Avidemux Crop filter:
 [Attachment 80851 - Click to enlarge]
	I am working on an small utility to do just that ..
 I haven't decided on Auto Crop yet ..
 [Attachment 88919 - Click to enlarge]Last edited by videoAI; 26th Sep 2025 at 06:40. There is nothing wrong .. with my environment
	There is a program called PavTube HD Video Converter; it crops video with real time visual support, and maintains the video and audio bitrates and most other attributes of the video of the input file. It uses avconverter.exe and is very fast.
	There is a program called PavTube HD Video Converter; it crops video with real time visual support, and maintains the video and audio bitrates and most other attributes of the video of the input file. It uses avconverter.exe, and is very fast.
  Simple to use MP4 Video EditorBy mjgreer in forum Newbie / General discussionsReplies: 16Last Post: 2nd Jul 2023, 11:30
  Video editor to do simple editing of AVCHD clips and burning to DVD / BDBy Petecjs in forum EditingReplies: 2Last Post: 15th Jan 2023, 06:48
  What's an easy to use, basic video editor for simple trimming operations?By CompVid in forum Newbie / General discussionsReplies: 10Last Post: 8th Jan 2023, 03:01
  i need a simple OGG editorBy sommers in forum Newbie / General discussionsReplies: 5Last Post: 7th Nov 2022, 08:54
  Simple Windows Video Editor That Allows Multiple Sounds OverlayedBy pone44 in forum EditingReplies: 6Last Post: 10th May 2020, 15:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
