I use VideoRedo to reduce file sizes to send on Whatsapp etc, and have sometimes run into trouble with formats that Whatsapp/Android can not play.
I have just done some testing to try and track down the problem, and it seems to be that our Android phones do not like interlaced.
To confirm this I tried to open some videos that would play, and resave them with the only change being to deinterlace. I tried both the various options on the main output profile screen (Deinterlace Auto/BOB/Smart etc), and also options in the advanced screen (Video Encoding Parameters > H.264 > Interlace mode > Progressive). Every combo I tried though still came out interlaced (checked with MediaInfo).
I could not for the life of me work out how I created the earlier mp4 h.264 files that MediaInfo showed as progressive, and did play on the phones.
I tried saving a MPEG4 .mp4 as deinterlaced, and this came out as progressive. I then opened this and resaved as h.264 and I finally had a h.264 progressive file again which played correctly!
Is this a bug within VideoRedo or am I missing something???
There are two completely different issues under an almost same name:
- interlaced content (the visible content of two fields in the video represent different moments in time)
- interlaced encoding (the encoder treats the content of both fields more or less separately)
MediaInfo reports the second one. It is not able to know anything about the first.
But instead of interlaced vs. progressive encoding, my guess would rather be that video decoders of mobile apps are limited in the support of a Profile@Level range. It might help to attach verbose MediaInfo reports of all your tested clips.
_
There is an opposite issue in the Windows Desktop app of Discord. But my discovery here was that it is not the video decoder: The mobile app can decode HE-AACv2, Windows only HE-AACv1 audio. -
If there's still an issue, why not continue in the original thread?
https://forum.videohelp.com/threads/415334-VideoRedo-not-converting-h-264-to-progressi...ays-interlaced)
VideoRedo not converting h.264 to progressive scan (stays interlaced)
By Vladimir81 in forum Video ConversionReplies: 7Last Post: 20th Jul 2024, 23:42 -
Converting interlaced 59.94 to progressive 29.97 with constant framerate
By skh in forum Video ConversionReplies: 11Last Post: 7th Jul 2024, 06:26 -
Progressive scan VHS players
By jeby1980 in forum Newbie / General discussionsReplies: 14Last Post: 11th Jul 2023, 17:45 -
Dropped frames after converting interlaced to progressive with VirtualDub2
By Hajker in forum Newbie / General discussionsReplies: 5Last Post: 16th Jan 2023, 07:09 -
interlaced mpeg2 ts viewing and converting to deinterlaced progressive
By patrick1 in forum Newbie / General discussionsReplies: 15Last Post: 3rd Dec 2021, 14:20
