Results 1 to 11 of 11
  1. Hello guys what you use to run and self host API for VT or devine i try with wvapi but dont have a right endpoint or maybe i wrong something, sorry im new of all this and try to run API with my own CDM, and my own vault with cached keys, but cant understood or found API who worked, if someone can share some link for what services to use for the run API. i Try with wv_cdm_api but not working or maybe i wrong something
  2. what end point i need to use on VT
  3. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    You could always run a getwvkeys clone, there's already quite a few out there
  4. If you have your own CDM, you do not need an API and can configure VT in this way:
    edit vinetrimmer.yml or that of your version/extension, add or edit these lines
    cdm:
    default: ‘generic_4464_l3’
    Netflix: ‘generic_4464_l3’
    Amazon: ‘generic_4464_l3’
    save and exit the file
    in the 'devices' folder if you do not have one, create a folder with the name
    generic_4464_l3
    and copy inside the two files:
    device_client_id_blob
    device_private_key
    then creates a file inside with the name
    wv.json
    with this content:
    "name": "generic_4464_l3",
    "description": "android generic 4464 l3",
    "security_level": 3,
    "session_id_type": "android",
    "private_key_available": "True",
    "vmp": "False",
    "send_key_control_nonce": "True"
    if you still need an API there should be a free one from CDRM project
  5. i have many cached keys for that i want to run and use my api i know how to use my cdm, i have and 2710 api for 1080p keys but want to use my own api with my cached keys, i have and L1 cdms but with vod platforms they has been revoked so fast and my devices will finish and need to order new for dump l1 lol.
  6. Originally Posted by RedRey View Post
    Your keys should theoretically be stored in the key_store.db file, to use them just use the --cache command
    --cache 'Disable the use of the CDM and only retrieve decryption keys from Key Vaults. If a needed key is unable to be retrieved from any Key Vaults, the title is skipped.'
    If you want to edit key_store.db you need a programme like ‘DB Browser for SQLite’.
  7. Thank you working
  8. Originally Posted by Karoolus View Post
    i think https://github.com/devine-dl/pywidevine would be a better choice but if you need help with setting up a getwvkeys clone let me know
    discord=notaghost9997
  9. cdrm-project.com
    Jun 2022
    USA
    https://GitHub.com/tpd94/cdrm-project
    Has devine / VT support built in for remote CDM and Vault, and has support for Fox refires WVG extension.
  10. Originally Posted by TPD94 View Post
    Thank you
