I have successfully ripped several DVDs now using Sefy's Classical Newbie Guide.
I assume these have all been fairly "standard" discs, since I haven't had to mess with many of the advanced settings in TMPGEnc, DVD2AVI, and SmartRipper.
What are these for and when do I need to use them?
•Interlaced/Non-interlaced (TMPGEnc)
•All the video arrange options besides "Full Screen (keep aspect ratio 2)" (TMPEnc)
•Forced Film (DVD2AVI)
These are only a few of the many options that I haven't had to use yet... when are all of these needed? I only ask because it seems like there's just so much EXTRA STUFF!
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Thanks, Mirror_Image.
I guess what I really wanted to know is: When would anybody actually USE these settings?
Sefy has indicated in another thread that he NEVER has to do some of the stuff that others do, and following his guide, I've never had to either. -
sefy's guides are for beginners. qualitative choices are limited for the sake of simplicity so as not to overwhelm. if the results you're getting are good enough for you then there is no reason to alter anything; however, know that it's possible to push your results further if you so desired
Just as stanwebber mentioned, my guides are aimed for newbie's, to help them get started, and get good results, there are more advanced guides, which would be a bit hard for beginers, but not for those who already know what they are doing, and teach how to tweak the settings more.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Settings TMPGEnc to FFMpeg
By Nologic in forum Video ConversionReplies: 0Last Post: 5th Apr 2012, 22:15 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 09:14 -
Help with TMPGEnc 4.0 XPress Settings
By mister_to_you in forum Video ConversionReplies: 0Last Post: 20th Jun 2008, 09:01 -
TMPGEnc DVD settings
By Bully9 in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 08:22 -
Doubt about TMPGEnc Plus' settings
By alvabass in forum Video ConversionReplies: 1Last Post: 13th Jun 2007, 11:52
