I have some 8K video files I want to down rezz to 4K, 1080P and even 480 SD. When downrezzing in Adobe Premiere Pro, does it oversample the video file, making the lower rez's sharper (like when you use Photoshop and reduce rez using the "Sharper" option for the downrezz)? Or does Premiere Pro throw away that extra information, making the downrezzed file softer as a result? I'd like to get the crispiest 1080P and 480SD files possible from the original 8K file, but concerned downrezzing with just throw away all that extra sharpness of the 8K file.
For 1080P to master to a Blu Ray disc (burn as a playable Blu Ray), what bit rate should I aim for that a Blu Ray player would make use of, while maximizing the quality? What about SD and burning to a DVD?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
gotta lose something to get to lower res, keep it 8k AV1 500kbps
depends on codec
avc - 8-13mbps
mpeg 2 - 15-18 mbps
try it, do a 5-10 second encode and see
wouldn't do it unless it's demanded, 720p should be minimum to deliver.make video everyday -
I have a reason for burning to DVD. Anyway Im aware you lose something when downrezzing, but the point I was trying to make, that at least when doing still pictures, when you downrezz, it gives you the option to make the lower rez image sharper (by the oversampled higher rez image). I dont know if video will do this as an option too?
What is the best way to compress video without losing any video quality??
By DJboutit in forum Newbie / General discussionsReplies: 26Last Post: 7th Aug 2023, 16:29 -
how to make a hardsub without losing quality?
By jessezveneberg in forum SubtitleReplies: 8Last Post: 24th Jul 2022, 15:33 -
Need help understanding 1080p Vs 4K Video download quality
By Lycop in forum Newbie / General discussionsReplies: 2Last Post: 21st Apr 2022, 13:08 -
make jpg bigger without losing quality
By David Banner in forum Newbie / General discussionsReplies: 12Last Post: 8th Feb 2021, 17:01 -
How do I downscale a 4K video to 1080p Bluray quality?
By SomeoneNeutral in forum Authoring (Blu-ray)Replies: 3Last Post: 18th Sep 2019, 18:13
