Is there an issue out there involving win2k and the ATI drivers that limit avi captures to 352x288?
I'm using an ATI AIW RADEON and I use to be able to capture at that resolution fine w/HUFFY codec running on win98 and winXP.
Whenever I try setting that resolution in vDub now, it tells me that my capture device doesn't support that resolution.
The highest it lets me go is 352x288...
I've searched the net for articles about this issue, but can't really find much.
It seems like a lot of other people have sufferred the same thing though.
Anyone know how to resolve this other than changing my OS?
Problem solved...
Anyone else who has this problem, go here:
http://forum.vcdhelp.com/viewtopic.php?t=77807
Follow the instructions...
Worked for me...
Might work for you...
640x480 VHS capture looks stretched on 50+ inch HDTV
By jrru2 in forum Capturing and VCRReplies: 11Last Post: 4th Nov 2011, 22:53 -
Vdub: Screen Capture
By dylz in forum Capturing and VCRReplies: 6Last Post: 12th Jan 2011, 17:24 -
Should I use 640x480 or 320x480 with cubic for VHS capture
By groove365 in forum Capturing and VCRReplies: 4Last Post: 1st Sep 2010, 02:23 -
split fields in vdub capture
By greenbag in forum Capturing and VCRReplies: 0Last Post: 18th Jan 2009, 23:50 -
AverTV Studio capture problems at 640x480
By SuperFlyBaconG in forum Capturing and VCRReplies: 1Last Post: 3rd Aug 2007, 06:34
