Hello,
As an alternative to a camcorder to record live meetings, I'm thinking of using a laptop with OBS.
Video can be captured with a webcam, but what are the options to capture audio?
Depending on the context, I could either use a microphone or run an audio cable from the mixing board/loudspeaker to the computer through either USB or the mic input.
What affordable hardware would you recommend?
Thank you.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Most modern webcams have built in microphones. Plugging into a USB socket will make your OS see a video device and an audio device so no external mic would be needed.
Note the OBS can be used but it is really for broadcasting rather than recording, it is an excellent program but you might find ones better for capturing and recording.
Brian. -
Thanks for the idea. In case the laptop is too far from the audio source, I'll have to run a cable from the computer for better performance.
What other Windows software should I look at for capturing and recording? -
make video everyday
Thanks for the idea
Apparently, line-in requires adding a DI unit before connecting it to the computer's mic input.
What about using a good quality microphone instead? -
Android or apple might be easier to use for camera and audio.
I might go that way if a laptop + microphone + webcam + recording software doesn't work well.
Weird glitching when recording with Hauppauge USB Live 2
By g38lm in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jun 2023, 22:53 -
video recording/downloading software for live streams
By helpful55 in forum Video Streaming DownloadingReplies: 5Last Post: 30th Jan 2023, 20:29 -
Is it possible recording 1-2 hours of this live HLS stream using VLC?
By SweX in forum Video Streaming DownloadingReplies: 9Last Post: 24th Aug 2021, 11:19 -
Steaming Meetings
By tahill79 in forum Video Streaming DownloadingReplies: 0Last Post: 18th Jul 2020, 21:23 -
AVerMedia Live Gamer Portable Lite - Not Recording Audio
By PureChaosX in forum Capturing and VCRReplies: 2Last Post: 19th Oct 2019, 12:42
