ok, i've read the how to but it's a little vague on joining. to join 2 or more files into 1 seemless file in tmpeg, you use the add button to insert the files you want, in the proper sequence and just hit ok. is that right? double clicking on the file is for cutting only. thanks.
If you are using TMPGEnc, then just add the files in the order you want to join them, select the output file name, and click on the join button. A screen will pop up with the audio and video times on it. That's all there is to it!
My shameless plug - XavierEnterprises.net
Joining MP3's
By dfisher052 in forum AudioReplies: 24Last Post: 28th Mar 2013, 06:57 -
Joining 2 Subtitles
By ashwin.terminator in forum SubtitleReplies: 2Last Post: 18th Apr 2009, 06:30 -
Joining WMV's?
By Flarch in forum MacReplies: 8Last Post: 18th Apr 2009, 04:47 -
Improper joining?
By LWC in forum EditingReplies: 6Last Post: 21st Mar 2009, 19:58 -
Joining
By breeze9 in forum EditingReplies: 2Last Post: 30th Dec 2007, 15:14
