  1. Hi, I have many F1 DVDs i want to convert properly for playback. I do believe they are all encoded the same way so I've only included one sample. Could anyone tell me what the best settings would be for Handbrake or ffmpeg (I'm only linux so limited to those 2)
    Here's some info from MediaInfo.
    Frame rate mode : Variable
    Frame rate : 3 378.853 FPS
    Original frame rate : 25.000 FPS
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan type, store method : Separated fields (2 fields per block)
    Scan order : Top Field First
    Thank you!
  2. It's a pain to get set up but QTGMC in AviSynth will give you the best deinterlacing. There are many options but here's the default...
  3. a. Vapoursynth is available on Linux too.
    b. no clue whats best when using ffmpeg or handbrake, but bwdif and nedi are supported in ffmpeg so I would look into those.
    users currently on my ignore list: deadrats, Stears555
  4. thanks, I'll check that out, from my understanding, the target FPS should be 50?
    Mar 2008
    Yes, if you want to keep that motion smoothness
  6. Member The_Doman's Avatar
    Feb 2004
    Netherlands
    But playback on what device(s)?
    A TV or any decent media player can play those interlaced DVD files fine interlaced as is.
  7. Here's bwdif in AviSynth. It's very similar to bwdif in ffmpeg. Notice much more buzzing there is on sharp, near horizontal lines, compared to QTGMC. bwdif is much faster though.
    Yadif is similar to bwdif but often leaves lots of little dots in deinterlaced areas.
