hi everyone i have got a question i need to ask everyone
i burnt some dvd movies with nero video nero software it is about 12gb it has burnt them as 2 folders audio.ts and video.ts with all the files in each folder
anyway what i want to do is if i can is can i shrink the folder with a software to 8gb to put onto a dvd disc. i know that you can shrink video files smaller but this is different cos this has been burnt with nero as a dvd folder. can i use a software to shrink it to 8gb and still keep the quality then burn it to disc
i know that you can do that with video files but can you shrink a dvd folder with the audio,ts and video.ts files in it.
if anyone knows of any software that will do this method
DVD shrink will probably do it but I'd be concerned about the layer break getting messed up.
I'd be redoing it with Nero (only one generation loss) and force it (Nero) to create a proper, compliant, Dual-Layer DVD VIDEO_TS folder or ISO.
Merge video, audio and subtitles in one folder using ffmpeg + bash script?
By oknchm in forum Newbie / General discussionsReplies: 1Last Post: 16th Nov 2022, 01:58 -
How to batch merge video & audios with same name inside a folder in Windows
By maxteddy in forum Video ConversionReplies: 4Last Post: 31st Jan 2022, 11:58 -
Burning DVD video from a VIDEO_TS folder
By GuyG in forum Authoring (DVD)Replies: 8Last Post: 9th Jul 2020, 19:23 -
Finding audio steam details for hundreds of video files in a folder at once
By kingmustard123 in forum EditingReplies: 2Last Post: 14th Jan 2020, 04:47 -
How can I set Streamlink default download folder & automatic file name?
By jaibubwan in forum Video Streaming DownloadingReplies: 2Last Post: 12th Sep 2019, 22:47
