I have just had time to investigate this issue further, and check whether my mp4 videos are lagging on Youtube in case they are being streamed as VP9 or not. As it was mentioned in my starting post, I found samples on Youtube that are not prone to lagging, and those are being streamed as VP9 unlike my videos. I upscaled my video to 4K, and now it is being streamed as VP9 as well. The result is: the playback is smoother, less prone to lagging. Not as good as the sample of others I found online, but there is a significant improvement, even if I watch the video in 4K, not only FullHD. No occasional slowing down of the playback when moving the mouse pointer on the screen. The video playback stops for the fraction of a second sometimes (only the video not the sound), that is the only symptom left, but it is way much better than in case of mp4 streaming. So all in all VP9 streaming gives a smoother result, even on machines like mine, and it prevails in case you watch the video in higher resolution, too. It seems there are some other still unknown things as well that should be improved somehow, but simply by upscaling the video to 4K and thus forcing Youtube to stream VP9 is already an improvement.
Results 31 to 34 of 34
If you are using Win10 or Win11 you can use Task Manager to view the GPU usage.
[Attachment 81023 - Click to enlarge]
You'll be able to see if the GPU(s) is being used to decode. -
There is high chance that VP9 is decoded by CPU with minimal GPU involvement and AVC may be decoded in HW by GPU thus some delay introduced in decoding path...
Only valid comparison can be done if both versions (AVC and VP9) are available from Google offline (locally on disk) - then software decoding and comparing...
Any version of x264.exe with mp4 output?
By Bencuri in forum Video ConversionReplies: 3Last Post: 31st May 2024, 09:47 -
No longer able to download videos with youtube-dl.exe
By BRH in forum Newbie / General discussionsReplies: 25Last Post: 3rd Mar 2023, 21:22 -
How to get rid of blocks when encoding with x264.exe
By arthurm in forum Video ConversionReplies: 5Last Post: 9th Aug 2021, 19:56 -
Please help with x264.exe command line for Full HD video
By Bencuri in forum Video ConversionReplies: 1Last Post: 24th Nov 2020, 19:52 -
youtube-dl.exe and Final Video Downloader problems that i have
By sommers in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2020, 10:52
Quote![Computer details: [Workstation]
Motherboard - ASRock WRX80 CREATOR R2.0
CPU - 24 Core 48 Thread AMD Ryzen Threadripper PRO 5965WX
CPU Cooler - Phanteks Glacier One 360M25 G2 AIO Liquid CPU Cooler
RAM - G.SKILL TridentZ RGB 16GB [8 x 16GB] DDR4 4000
GPUs - [2x] RTX A6000s with NVLink
Optical Drive - LG Electronics 16x SATA M-Disc DVD Rewriter
Hard Drives - Kingston FURY Renegade M.2 2280 1TB PCIe 4.0 x4 NVMe, 4x Mechanical Hardrives, 16.382 TB total storage
Case - Cougar MX330 Mid Tower Case
Monitor - GIGABYTE MO34WQC2 34" QD-OLED Curved 3440x1440 240Hz
Headset - Corsair VOID WIRELESS v2
Keyboard - Z-EDGE
Mouse - Rosewill NEON M62 10000 DPI, 9 Button Comp](/images/buttons/computer.gif)
