Hello all,
I do have a powerful PC with 2 Magewell devices (USB and PCIe). We successfully capture live video, but during movement you sometimes see the video stuttering / tearing, not significantly, but it does. There is 0 framedrop. When we play the recorded video, there is not tearing / stuttering at all.
The video comes from a Sony 9520L Full HD block, which is the converted into analog HD (component) and SDI.
Looking at the second monitor using SDI 60 Hz you see a perfect video, but the live picture on the PC has the effects described above.
Funny thing is, the more refresh rate you set for your monitor, the effect gets better.
What struggles me is that playing the same video from VLC does not show these effects.
Many thanks in advance, Marcus
Results 1 to 1 of 1
Audio from 25 fps in 23,976 fps video always out of sync even if converted
By Huggy in forum AudioReplies: 5Last Post: 2nd May 2023, 05:05 -
VirtualDu2 (I'm having trouble capturing video at consistent 29.97 fps)
By reel-images in forum Newbie / General discussionsReplies: 0Last Post: 10th Jan 2023, 08:06 -
Stuttering Playback Issue with DMR-ES10 recorded DVDs
By autephex in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Apr 2022, 01:00 -
Does increasing fps 30-->60 when (ffmpeg) re-econding repair stuttering?
By pxstein in forum Newbie / General discussionsReplies: 1Last Post: 24th Aug 2021, 09:41 -
Capturing analog video recorded onto 8mm Data Tapes (Data8)
By infjmm03 in forum Capturing and VCRReplies: 2Last Post: 11th Sep 2020, 21:35
