    Feb 2022
    Search the forum first!
    Pip is the package manager by default for Python. However, it is old with one or two niggles in use. If some script author has put a limit on the acceptable version of a module in requirements.txt, should you try to update it, then pip will complain. Also installing a list of modules can take some time.
    There is a new kid on the block - uv. https://astral.sh/blog/uv
    Install by:-
    Linux
     curl -LsSf https://astral.sh/uv/install.sh | sh
    Windows
    powershell -c "irm https://astral.sh/uv/install.ps1 | iex"
    Via pip (yes, I see the irony!)
    pip install uv
    • Uv handles modules imports quickly and easily.
    • Uv allows more than one version of python to be installed and used
    • Uv allows the override of requirements.txt to install up-to-date modules for old scripts
    In use as a package manager just preface pip commands with uv
     uv pip install yt-dlp  --upgrade
    [Attachment 80570 - Click to enlarge]
    uv pip install -r requirements.txt
    [Attachment 80571 - Click to enlarge]
    In use as a Python environment manager:
    uv venv
    [Attachment 80573 - Click to enlarge]
    And uv gives prompts on how to activate the environment.
    [Attachment 80574 - Click to enlarge]
    The Astral blog says uv isn't a 100% replacement for pip yet. But for my use I haven't found it wanting. Fast and helpful. Recommended.
    Noob Starter Pack. Just download any Widevine media! Over 22,000 downloads for V6!.
  2. Looks very interesting thanks going to try it out
