    Mar 2008
    Singapore
    The only relevant thread I found was 10 years ago - IM sure tech has evolved since then.
    https://forum.videohelp.com/threads/369074-Is-there-a-way-to-make-PotPlayer-automatica...load-subtitles
    Is there a more seamless way for potplayer to detect what video I'm playing, and retrieve the subs in the background and display once downloaded?
    Dec 2017
    Canada
    There's an option under Preferences > Extensions > Subtitle searching
    I've never used it, so you'll have to figure it out. Your video should probably have the proper filename.
    There's another option, Preferences > Subtitles > Subtitle searching. I'm not sure how this one is used.
    When I need subs, I usually just download them from a website.
    Mar 2008
    Singapore
    that option is not automatic - it just gives you a shortcut to download subs.
    Dec 2017
    Canada
    I just tried the Extension one, you select what you want it to do from the 2 drop down lists, and it automatically gets and loads or displays the subs.
    Don't check "Show the dialog..." if you don't want that; that popup lets you select the subs you want.
    Mar 2008
    Singapore
    May I check if this is the place you're referring to?
    [Attachment 80602 - Click to enlarge]
    Mine doesn't auto-download and display.
    Dec 2017
    Canada
    Preferences > EXTENSIONS > Subtitle searching
