I took the videos with a Galaxy Note 20 Ultra 5G smartphone, and then transferred them to my PC using Feem. After I uploaded it looked fine on youtube
Good quality video https://www.youtube.com/watch?v=JYKF3ETQs2E
But, bad quality when viewing in it VLC before I uploaded it, here..........
https://www.youtube.com/watch?v=275yu9Giy_E
almost doesn't even move framewise, though the audio is fine.
				Results 1 to 17 of 17
	Yes,they are unlisted, but I gave you the direct URL's you should be able to watch them, shouldn't you?
	The second link looks like a screen capture. What did you do exactly?
	Yes, like I was saying (well it's in the video description), I had to do a screen capture to show you what the bad one looks like, because youtube fixed the bad one when I uploaded it to them. I used OBS and took out a segment/part of it with premier pro, but the full version looks bad too, so I know it wasn't premier pro that made it look that way.
	Says the max file size for an MP4 to upload as an attachment is 500MB, but I'm having trouble that it doesn't even start uploading it to here. At least I see no progress bar moving
 edit- nevermind it worked.Last edited by videofan70; 9th Jul 2024 at 20:06.
	There's nothing wrong with the file. I had no problems playing it here with VLC (i9 9900, RTX 4060). I suspect your computer (Core Duo CPU T8300) just doesn't have the power to play it.
	Then why does it play fine on youtube, what did it do to it to fix it when I uploaded it. My computer had like 48 gigs of ram. If it's that what hardware is lacking? Just the CPU. I had to use a high bitrate because the lowest one wasn't recording it at all on my phone. Though I could try some in-between.
	Nothing inherently wrong with video, just needs a strong CPU and/or a GPU to play it properly.
 Youtube reencodes the video to a much lower bitrate
	GTX 670 doesn't support H.265 decoding, so no assist from the GPU unfortunately
  uploading mkv instead of mp4 to youtubeBy codemaster in forum Software PlayingReplies: 3Last Post: 11th Dec 2023, 21:22
  YouTube Uploading Qualities From a SD File to 480p vs 720p vs 1080pBy dellsam34 in forum Video Streaming DownloadingReplies: 0Last Post: 31st Jul 2022, 19:31
  Screen capture video becomes blurry when editing / uploading to YoutubeBy Bencuri in forum Video Streaming DownloadingReplies: 5Last Post: 15th Feb 2022, 08:50
  YouTube sound but no video Face Book and other Web Browser media is FineBy dashas in forum Newbie / General discussionsReplies: 10Last Post: 15th Jan 2021, 00:27
  Problem with choppy audio after uploading to Google Drive or YoutubeBy dg415 in forum Video Streaming DownloadingReplies: 15Last Post: 4th Nov 2019, 22:33
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
