this is the website i want to download Alien Isolation mission 8
https://www.youtube.com/watch?v=0MWwf82sPkA&list=PLVQ6T3bxoOVo-DdskI4FQFygSLZLEMOGp&index=9
yt-dlp.exe
with ffmpeg 7.0.1 Windows 64-bit
yt-config.txt has
--format best
--output '%(title)s.%(ext)s'
yt-dlp.exe makes 640x360 resolution and its subtitles are too mushy
could you fix my yt-config.txt for me to download 760p as 1st priority and maybe 1080p too (because 1080p could be too big a file)
Your source has a 720p60 version of that video. To download it, you can use a .bat file referring to the youtube's code for that resolution (298) and m4a audio type (140):
Code:yt-dlp -f 298+140 "https://www.youtube.com/watch?v=0MWwf82sPkA" pause
Codes for the other available resolutions can be found for that URL using another .bat file:
Code:yt-dlp -F "https://www.youtube.com/watch?v=0MWwf82sPkA" pause
SET P0=C:\Programs\YOUTUBE-DL
SET P3=aria2c.exe
SET P4=%P0%\WIN10\yt-config.txt
SET F5=--ffmpeg-location "C:\Programs\FFmpeg\ffmpeg.exe"
REM ----------------------------
SET G1=--no-part
SET G2=--format-sort res:720
SET G3=--compat-options multistreams
SET G4=--external-downloader %P3%
SET G5=--config-location %P4%
::SET G6=--output '%(title)s.%(ext)s' does not work in command line
::it must be implemented in --config-location yt-config.txt
yt-dlp.exe %F5% %G1% %G2% %G3% %G4% %G5% "website address"
I forgot many ffmpeg.exe and yt-dlp.exe command line syntaxes at the moment
why doesnt --output '%(title)s.%(ext)s' work in command line? and it only works in --config-location yt-config.txt
now i kind of remember the reason i used --format best was it made all output to MP4
but when --format-sort res:720 was used, it made webm or mkv
1st stage it makes aaa.f289.mp4 video then
it makes a sound aaa.webm file
then it turns them into a aaa.mkv
is there a way to make a final output as MP4? without going through ffmpeg.exe again
I forgot where i got this --output '%(title)s.%(ext)s, it is not in yt-dlp.txt
--output '%(title)s.mp4' didnt work
--output bbbb.mp4 didnt work, it just makes bbbb.mp4.mkv
mkv is slower than mp4
mkv doesnt scroll well like fast forwarding or rewinding
i dont have a mkv cutter and joiner -
ytdlp-interface made mp4, worked well as to where my batch with my syntax understanding about ffmpeg.exe and yt-dlp.exe failed.
but i still need to do with my "drag and drop batch" for windows explorer and a batch file that links with ztree
SET URL=%*
this command makes a drag and drop batch possible
i didnt include in above but i also need these
SET F1=--write-auto-sub
SET F2=--sub-lang en
SET F3=--sub-lang de
SET F4=--convert-subs srt
SET H1=--exec "C:\ZTREE\SHELL-VIDEO.BAT"
SET H2=--output "M:\zzz-temp.MP4" (... didnt work well)
in other words, i can max&growing-customize with only a batch file and i can put some batch intelligence into it.
i would like to ask how to convert mkv to mp4 in ffmpeg.exe post some other time.
i have done this a little bit before, and i forgot much, because currently i dont have a batch file for it.
yt-dlp -f 298+140 "URL" made mp4 and worked well and downloaded about 2 times faster than when aria2c.exe was used(does this mean aria2c.exe is not that good anymore?)
but i dont know what 298+140 means. the numbers seemed to differ by every other different videos and how would i determine these possible variables? -
there are many questions here, maybe not organized, please keep that in mind
yt-dlp.exe - 20240707.exe has the same download rate text colors as when aria2c.exe was used. so i think a new yt-dlp.exe probably integrated with aria2c.exe
is there any chance that NEW yt-dlp.exe could download ~1k or ~10k or ~100k bytes/sec, low bit(converted to byte)rate?, i observed this ~10k and ~100k bytes/sec few times. these were the behaviors of Youtube-DL.exe and old yt-dlp.exe before aria2c.exe was introduced, and with it i have never experienced with yt-dlp.exe taking the low bit rate past several years
--format best worked with a new yt-dlp.exe till 2~3 day ago, but currently --format best syntax is NOT working at all with any kind of yt-dlp.exe, old versions and the newest version... this is very strange, i deleted any left cache, no work....is there other cache location or setting location other than C:\Users\AAA\.cache\yt-dlp\ or where yt-dlp.exe was installed?
--format best had a better quality than --format-sort res:360... i need to verify this more. but --format best is not working any more. now i can only tell this by comparing the old videos with the new same videos with --format-sort res:360
all of sudden, yt-dlp.exe DOES NOT convert it to MKV anymore, at the same time --format best is broken in mine, i dont know why
i think --format best probably used the lowest resolution that youtube provided, because i had many videos with 720 with it. and the speed of whatever related(downloading and sampling and codecking or something)was great,
i learned that --format-sort res:720 chooses the resolution closer to 720 from what the youtube video originally provides, thereofore -sort res:NUM doesnt take 600 or 640 or.. any numbers other than 360 480 720.... this will help me greatly
SET G1=-f "bestvideo[vcodec^=avc1][height<=1080]+bestaudio[acodec^=mp4a]/best[vcodec^=avc1][height<=1080]"
SET G2=--format best
yt-dlp.exe %G1% %G2% URL
past several years, i used %G1% %G2% both to make subtitles work as below, although now i forgot why two and how, or it was maybe my imagination or maybe was a strange tweak.
maybe if you can add few words as to what the long G1 does? because it makes 1080 and not 720
now i changed old G1 and old G2 to a new G2=--format-sort res:720 only
my final thought
*not making MKV was a big help
*--format-sort res:720 takes a resolution closer to the original contentsLast edited by sommers; 11th Jul 2024 at 22:52.
Download from goplay.be using yt-dlp
By heidy333 in forum Video Streaming DownloadingReplies: 33Last Post: 1st Sep 2024, 15:36 -
Need help for download with yt-dlp
By sibhus in forum Video Streaming DownloadingReplies: 26Last Post: 19th Feb 2024, 15:02 -
Help with YT-dlp batch download
By Loryanam2 in forum Video Streaming DownloadingReplies: 2Last Post: 13th Feb 2023, 15:00 -
YT throttling and how to fix it. (YT-DLP)
By DB83 in forum Video Streaming DownloadingReplies: 6Last Post: 4th Sep 2022, 02:40 -
How to fix the download failure with yt-dlp command for some live M3U8 link
By zydjohn in forum Video Streaming DownloadingReplies: 12Last Post: 26th Nov 2021, 14:35
