All same equipment and programs.
No frames dropped in W2K.
Nothing but frames dropped in XP.
Is there some setting in XP that needs to be tweaked or disabled?
Or will Virtualdub just not work under XP?
I'm sorry I don't have a solution for you, but I wrote to commiserate. I've been having lots of problems using Virtualdub in Windows XP too. Anytime I want to use Virtualdub for the entire length of a movie file, it either hangs and doesn't work on the movie, or it crashes. I wrote another post about Graphedit not working properly in Windows XP as well. Go figure. Hope you get some feedback that will solve my problems too
Good Luck!
I was surprised an ip masker really really worked
By yoda313 in forum Off topicReplies: 0Last Post: 22nd Feb 2011, 15:49 -
I have tried many media converters for HD, none of them worked
By calande in forum Video ConversionReplies: 2Last Post: 11th Jul 2010, 21:02 -
BD rebuilder worked; how to reset the beta
By TomBud in forum Blu-ray RippingReplies: 9Last Post: 3rd Jan 2010, 16:30 -
renamed .mp4 to .avi and worked
By eeyaphew in forum MacReplies: 0Last Post: 8th Apr 2008, 20:09 -
.MKV to DIVX worked but not really
By cabala in forum Video ConversionReplies: 7Last Post: 7th Oct 2007, 19:58
