  1. How can I convert a single PNG into a five-second MP4? High quality is important. I would appreciate an FFmpeg solution but will use alternatives.
  2. Never mind. I already knew the answer. I used IrfanView's Slideshow > output to video.
  3. Code:
    ffmpeg -loop 1 -i image.png -t 5 -c libx264 -crf 18 -vf fps=24000/1001,scale=1280:720 output.mp4
    where
    -t is the duration in seconds
    -c is the video codec, in the example x264(avc)
    - crf is the quality (0-28, lower is better)
    fps is the framerate, in the example 23.976 (24000/1001)
    scale is the resolution, in the example 1280x720
    Adjust the parameters as required.
  4. Thanks! Looking forward to trying it.
