  1. I'm trying to get the closed-captions for a show. I got the key and I got the mpd and thus the audio and video, but the subtitles are separate from the mpd. N_m3u8DL-RE lists all the video streams and audio streams, but says there aren't any subtitles.
    I think this smi holds the captions, but when I open it it clearly states
    SYNC Encrypted="true"
    Is it possible to decrypt them? If so, how? If asking this is against the rules then I apologize and just ignore me.
    I tried searching the forum, but anything I found didn't seem to work.
    Thank you for any help.
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Video URL?
    Edit: nvm, found solution thanks to @larley proving it can be done. Just use this
    https://gist.github.com/jkmartindale/6a3b81e5baed5c8eb766a8b65374b3cb
    Last edited by 2nHxWW6GkN1l916N3ayz8HQoi; 7th Jul 2024 at 10:46. Reason: found solution
  3. here you go
    Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
