I am using SM Player on Windows.
Please go to https://github.com/boned101/MPV-Custom-Shaders/tree/main. It has adaptive-sharpen.glsl and SSimSuperRes.glsl.
Also please go to https://github.com/butterw/bShaders. It has grain.glsl and contrast.10.hk.
I downloaded those 4 shaders and I put them in C:\Users\xyz\AppData\Roaming\mpv\shaders.
I was able to make adaptive-sharpen.glsl work in SM Player by going to preferences --> advanced --> mpv and then I put the below line under options:
--glsl-shaders="C:\Users\xyz\AppData\Roaming\mpv\shaders\ adaptive-sharpen.glsl"
I confirmed that it worked by pressing shift and I twice and it said adaptive-sharpen in the info screen. Next I tried:
--glsl-shaders="C:\Users\xyz\AppData\Roaming\mpv\shaders\ SSimSuperRes.glsl"
--glsl-shaders="C:\Users\xyz\AppData\Roaming\mpv\shaders\ contrast.10.hk"
--glsl-shaders="C:\Users\xyz\AppData\Roaming\mpv\shaders\ grain.glsl"
but nothing happened and those 3 shaders didn't show when I pressed shift and I twice. Why is that?
Also I only know how to use one shader at a time. What do I type under options so I use more than one shader at the same time? I need to use a sharpening shader, a grain shader and a contrast shader at the same time.
SSimSuperRes does not activate on native resolution, that means you would have to slightly zoom in for it to start working
What shaders should I use in potplayer?
By cns00 in forum Newbie / General discussionsReplies: 37Last Post: 6th Apr 2024, 09:27 -
Pixel-shaders for video playback (.hlsl, .glsl)
By butterw in forum Software PlayingReplies: 41Last Post: 2nd Apr 2024, 16:21 -
[A-Pack v1.50, Open-source] Video-player Adjustments shaders Pack.
By butterw in forum Latest Video NewsReplies: 2Last Post: 20th Nov 2023, 09:58 -
help needed to download a yt video (the usual programs don't work)
By olli66 in forum Video Streaming DownloadingReplies: 4Last Post: 4th Jun 2021, 02:10 -
FREE motion interpolation solution (Uplavnyalka), pixel shaders
By DanilaZabiaka in forum Newbie / General discussionsReplies: 6Last Post: 18th Oct 2020, 10:54
