I read all the threads and tried to download this one:
https://mediasetinfinity.mediaset.it/video/sissi3/episodio-1_F312726703000101
I believe i found the right link
https://vod06.msf.cdn.mediaset.net/farmunica/2024/06/1598665_1900692fd65d01/dashrcenc/hr_wv_mpl.mpd
and key
24e11cb6411a4d253c3a7c702e200e4b:b06a94b12ffc5e795 5291c258241f205
chiave
but running N_m3u8DL-RE I always receive an error
ffmpeg not installed (and it is) and INFO that is a beta release
18:18:39.932 INFO : N_m3u8DL-RE (Beta version) 20230628
18:18:39.964 ERROR: ffmpeg not found, please download at: https://ffmpeg.org/download.html
ffmpeg is under C: and the variable environment confirmed.
Anybody can help with the correct string I have to write?
Thanks in advance for your kind help.
As the command said, ffmpeg isn't installed. Install ffmpeg : https://www.ffmpeg.org/download.html
simply put ffmpeg.exe in the same folder as N_m3u8DL-RE and also put mp4decrypt.exe, then as mentioned in almost all posts about mediaset to get 1080p you have to replace hr with hd
Code:https://vod06.msf.cdn.mediaset.net/farmunica/2024/06/1598665_1900692fd65d01/dashrcenc/hd_wv_mpl.mpd
Need help to download drm-protected video from Mediaset Infinity
By speedbob in forum Video Streaming DownloadingReplies: 423Last Post: 25th Nov 2025, 11:22 -
how get pssh key from mediaset
By cristinas in forum Video Streaming DownloadingReplies: 46Last Post: 23rd Oct 2025, 13:10 -
By nette in forum Video Streaming DownloadingReplies: 19Last Post: 2nd Jul 2024, 15:10 -
Key for mediaset
By Hammer in forum Video Streaming DownloadingReplies: 10Last Post: 2nd Nov 2023, 11:23 -
Mediaset Play
By djg666 in forum Video Streaming DownloadingReplies: 4Last Post: 15th Nov 2021, 03:32
