I got this Philips DVDR3575H DVD Recorder for free. It has both optical drive reader and HDD and HDMI output and it can upscale analog signal to 1080p.
But I cannot tell if the unit has line TBC and how it can be enabled. I tried to pass video from VHS both through analog out and HDMI out but it doesn't seem to make any noticeable difference.
Is anyone familiar with this model or similar models from Philips?
I can provide internal pictures from the unit if you want
Results 1 to 12 of 12
Pal or ntsc signal ?
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
I don't know this specific model but i guess try the different inputs (front/back), some decks are notorious for that
Annoyingly, the EU and US versions use the same model number but are completely different internally.
US DVDR3575H/37: Funai design, has line TBC (Panasonic chip from what I've read)
EU DVDR3575: Philips design, no line TBC (SAA7136 according to service manual)My YouTube channel with little clips: vhs-decode, comparing TBC, etc. -
I know that it wont improve video quality. What isn't there wont be there even after the up-scaling. It could be handy to upload to Youtube if I follow the option to capture with HDMI to USB device without need to manually upscale it. Uploading to Youtube videos with resolution less than 1080p is a very bad idea because the compression makes a visible difference, especially at 480p.
That one has it.
I saved a Sony DVD recorder from the recycle bin.
Optical drive fails to read CDs/DVDs but I don't really care about that.
Does this model have TBC that can be used as passthrough?
The model is Sony RDR-GX210 -
RDR-GX210 doesn't have any particular horizontal stabilization / line TBC.
The 2nd digit indicates the model series or "generation". The 5-series that you have now is the earliest Sony that is worthwhile for passthrough.
Originally Posted by Jarvis on DD86 Discord
You can refer to this informative comment on a YouTube comparison about the DVD recorders based around this particular NEC chipset.
Originally Posted by YT comment by oln / hodgey / AnalogVideoChannel, w/some typos correctedMy YouTube channel with little clips: vhs-decode, comparing TBC, etc. -
Here is an overview of which PAL Pioneer/Sony devices should be suitable:
https://forum.videohelp.com/threads/414397-Which-of-these-DVD-players-can-be-used-from...BC#post2739171
Error "DVD is full " with Philips recorder DVDR3455h/37
By 1234567 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Jul 2024, 21:42 -
My LG DVD recorder are formatting my Philips DVD-RW disks in a endless loop
By Joscraft_05 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 29th Sep 2023, 22:44 -
I fixed my Philips DVDR 3455H dvd/hdd recorder
By dphirschler in forum DVD & Blu-ray RecordersReplies: 72Last Post: 21st Apr 2021, 17:05 -
Philips DVDR3575H Questions
By belder in forum DVD & Blu-ray RecordersReplies: 47Last Post: 10th Jun 2020, 19:16 -
Region Free DVD Recorder with TBC (update)
By Cherbette in forum Capturing and VCRReplies: 15Last Post: 16th Sep 2019, 07:46
