When playing Rec.709/SRGB sources, will colors appear more saturated on a display designed for the Rec.709/SRGB color space than on a display designed for the BT.2020 color space after setting it to its Rec.709/SRGB mode? Why is it that on my HP SPECTRE x360 15T-df0070NR 2018/2019 model laptop's internal AMOLED display, when I have HDR turned off in Windows 10 and Windows 11, Rec.709/SRGB looks fantastic, yet when HDR is turned on, Rec.709/SRGB appears undersaturated, yet HDR BT.2020 looks fantastic? Why is it that on my Sony Bravia XR85X90CL 2023 model Full Array Local Dimming LED display, with color space set to Auto, Rec.709/SRGB sources appear undersaturated, while HDR BT.2020 sources look fantastic? Why am I having less difficulty with Rec.709/SRGB on my laptop than on my home theater display?
Results 1 to 1 of 1
Convert rec.601 into rec.709?
By killerteengohan in forum RestorationReplies: 8Last Post: 15th Jun 2021, 18:25 -
I just captured VHS with a Rec 709 colors space instead of Rec 601.
By jpvoodoo in forum Capturing and VCRReplies: 4Last Post: 25th Apr 2021, 11:42 -
Converting rec.709 to rec.601?
By killerteengohan in forum RestorationReplies: 22Last Post: 13th Jun 2020, 16:19 -
how to remove the exactly string colorMatrix(mode="Rec.601->Rec.709") ?
By marcorocchini in forum Newbie / General discussionsReplies: 16Last Post: 10th Aug 2019, 23:40 -
10-bit encodes with REC.709
By snadge in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2019, 14:14
