I've ripped lots of retail DVDs last 20 yrs using DVDShrink and I just looked at them and I think all those VOBs that I ripped came out 720x480. Is there a way to rip DVDs to HD VOB or HD MP4 files (1280x720)? (I don't think quality of my ripped VOBs came out as the same quality of the retail DVDs.)
Are there options in DVDShrink to rip DVDs to different VOB resolutions (1920x1080 or 1280x720)? Ultimately, I'd like to make HD MP4 files from ripped DVDs if that's possible.
	Simple answer is NO. The DVD standard is 720 x 480 or in the case of PAL discs 720 x 512 SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
	Then you possibly have ripped with DVDShrink set to fit the videos within certain boundaries. A much used workflow was to set target size to a single layered dvd-disc, forcing videos having to be recoded. At which point you are at the mercy of the encoding quality DVDShrink offers, also in relation to how much "shrink-ratio" is needed. It's been a while since I used DVDShrink, but from what I remember you can set it to not recode video, but rip as-is. Quality will be the same as the original disc but obviously output size will be bigger compared to "shrunk" videos.
 Any specific reason why you'd target mp4 container (and not stay with video-dvd or go for mkv for example)?
	Yes. After importing the DVD select 'No compression' in the Compression Settings tab.
 (Alternatively one can set in the Menu under Preferences .... a custom target size. Set it large enough and DVDShrink won't compress and will preserve the original quality.)
 Also keep in mind when converting to .mp4 or whatever one will loose the DVD menu etc., and just upscaling to HD resolution is usually pointless as it doesn't create any more details. It's still DVD quality.
 If you don't need the DVD menus you can probably also use MakeMKV to rip the video files to .mkv preserving the original quality.Last edited by Sharc; 2nd Jul 2024 at 05:03.
  Best GoPro Resolution to make DVD and BluRayBy BaruceBR in forum Newbie / General discussionsReplies: 21Last Post: 22nd Feb 2023, 10:49
  Exporting DVD Footage for Computer/Web: What Aspect Ratio & Resolution?By Eric H. in forum Video ConversionReplies: 21Last Post: 7th Dec 2022, 02:58
  DVD decrypter - merge wrong-splitted VOBs and keep menusBy SmurfRecorder in forum DVD RippingReplies: 4Last Post: 31st Aug 2022, 14:13
  DVD Playing more video that what is in the VOBs?By crbd98 in forum Newbie / General discussionsReplies: 9Last Post: 20th Feb 2021, 12:55
  Ripping Resolution/Aspect RatiosBy BYJAM in forum DVD RippingReplies: 8Last Post: 27th Jul 2019, 14:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
