Hi everyone, I'm here with trying to solve a problem I had recently, I've already use the search function but I couldn't find anything helpful,
I'm trying to use the timeshift buffer in OTT Navigator for some live channels.
Basically when I load the mpd manifest on my PC with Shaka Player I can travel until 2 hours back since in the manifest there is timeShiftBufferDepth="PT2H" and everything works fine.
When I load the same manifest in OTT Nav I can't travel back and each time the channel starts from live.
I've also tried to set in the m3u playlist the catchup type: timeshift but also other type of catchup but none seemed to work.
Is there anybody who can help me and managed to solve this issue?
Results 1 to 9 of 9
Got a link? Was struggling too with this, I got it to play but it was black with only subtitles.
for some reason I was banned from the tlgram group, (i just asked one question one day ...
could you please be so kind to post here, if you find the solution?
Txs a lot. -
I was also banned from that group just for asking that. It seems they are one of the most toxic community ever, I switched to tivimate and bought lifetime subscription and never looked back. I wish ott navigator dies and I will never recommend it anymore to any other user. Only tivimate or sparkle for me now.
OTTnav doesn't support it, I think the app that supports it is iMPlayer IPTV Player.
They can easily support it if they upgrade the exoplayer version. Exoplayer (media3) has already added this feature same as Shaka Player.
Basically the player must properly read the timeshiftbufferdepth tag included into the mpd manifest. -
I created a web IPTV player, it's using shaka player:
https://forum.videohelp.com/threads/416410-Free-web-based-IPTV-player-with-EPG-viewer-...-m3u8-playlist
Adding a free channel on OTT nav
By Stoc in forum Video Streaming DownloadingReplies: 19Last Post: 23rd Oct 2024, 12:30 -
Using Vimeo OTT
By AprilDDD in forum Newbie / General discussionsReplies: 0Last Post: 18th Sep 2023, 09:09 -
Repairing the timestamps of an IPTV/OTT H264 TS file?
By RedPenguin in forum EditingReplies: 5Last Post: 5th Aug 2020, 15:02 -
[HELP] Download from Vimeo OTT
By ozzy2k11 in forum Video Streaming DownloadingReplies: 0Last Post: 30th Jun 2020, 05:51 -
How to download catchup videos
By ThunderRanger in forum Video Streaming DownloadingReplies: 1Last Post: 5th Mar 2020, 00:04
