Has this program been discontinued by the company?
It was last updated 12 days ago:
https://www.videohelp.com/software/PotPlayer -
Daum PotPlayer 240618 (1.7.22266) changelog:
Added the ability to set the font for OSD playback information
Added the ability to name albums in environment management automatic conditions
Added the ability to go to the previous/next section in the section repeat list
Added ability to not wait for vertical sync
Added system media transport control function
Modified the window border skin to be prettier.
Modified the subtitle format to be displayed in the name of the built-in subtitles.
Fixed an issue where frame steps did not work properly in the built-in video renderer.
This shows that they are updating it more regularly than you would think. If you want the newest codecs than you need to usually do a complete uninstallation with the help of Geek Uninstaller or Revo Uninstaller to remove extra traces of the program. After you install the beta version of Potplayer, then you'd do the extra codecs installation along with a newer updated version of OpenCodec. I feel the installer for Potplayer is not good when you do a simple update installation.
*another note*: It would be nice if Potplayer did a better job on their subtitle rendering to look sharper like programs such as MPV, VLC, MPC-BE, MPC-HC, etc. -
Hmmm.. i'm using version 1.7.351!
The culprit to not self-update must be that is installed in Win 7 :/
Right?
Freezes in Pot Player after x265 encoding
By gelo333 in forum Newbie / General discussionsReplies: 0Last Post: 20th Mar 2023, 07:06 -
any know how to get pot player to do more than 2 channel audio?
By gkely in forum Software PlayingReplies: 0Last Post: 22nd Aug 2021, 21:03 -
Pot Player Playlist Add
By gggpot in forum Newbie / General discussionsReplies: 0Last Post: 8th Nov 2020, 14:28 -
Pot Player setup
By dbr97 in forum Capturing and VCRReplies: 3Last Post: 18th Sep 2020, 02:22 -
Pot Player problem with some video's
By Frederyck in forum Newbie / General discussionsReplies: 8Last Post: 18th Aug 2020, 01:33
