I'm trying to download the 1080p version of this Glastonbury recording:
I installed get_iplayer (latest version from GitHub), I used a VPN for UK and I used this command:Code:https://www.bbc.co.uk/iplayer/episode/p0j2mlt8/glastonbury-aurora
The problem is that this pile of unreliable software (apparently it was made in the horrible programming language Perl) always interrupts the download and gives errors. Is there any way to reliably download that video? Or at least to get the download link to grab it with either yt-dlp or streamlink? Those 2 programs can only detect 720p streams.Code:"C:\Program Files\get_iplayer\get_iplayer.cmd" --get --pid=p0j2mlt8 --tv-quality "1080p"
Results 1 to 30 of 37
Noob Starter Pack. Just download every Widevine mpd! Not kidding!.
https://files.videohelp.com/u/301890/hellyes6.zip -
N_m3u8DL-RE 'https://mm.bidi.bbc.co.uk/vod-dash-uk/usp/auth/vod/piff_abr_full_hd/d033b9-p0j2mt15/vf_p0j2mt15_690a3195-feec-42c9-811a-91fc92e953dc.ism/pc_hd_abr_v2_dash_master.mpd?at=MFTtRmVN01b59114285289b7f050a8ca3d147b22ae8cc31961c0dce539280' -M mkv --save-name 'glastonbury-aurora'
I would recommend using Devine - https://forum.videohelp.com/threads/414154-Devine-Modular-Movie-TV-and-Music-Archival-Software
Here is your video in 1080P: https://gofile.io/d/qtI30L -
What is this N_m3u8DL-RE? I can find this https://github.com/nilaoda/N_m3u8DL-CLI/tree/master without RE. Also how did you get that dl link?
You need to read the README on github I would say, and follow and ensure it's correctly installed and you have the proper neccessary tools in the correct place. After you have that, let me know and we can get you some service files installed. It's not necessarily the easiest thing to set up, but the most comprehensive and extensible, so I'd recommend you learn how to use it and then you'll be able to download many many things.
I'm willing to learn how to use Devine. I know some programming as well, especially Python.
So far, I installed Devine with pip install, I copied the iP service from https://cdm-project.com/stabbedbybrick/devine-services to the right folder that I got from devine env info.
I used the command
but I get the error "Failed to load Widevine CDM, A CDM to use wasn't listed in the config".Code:devine dl --list-titles iP p0j2mlt8
What should I install/configure next? -
Ah, excellent man - moving fast!
So next there's a few of ways you can go about it - you can either:
a) dump a CDM from a real or a virtualised Android device (guides are in the sticky threads)
b) Use one from this list : https://forum.videohelp.com/threads/413719-Ready-to-use-CDMs-available-here%21
c) Use a remote CDM in your devine configuration (https://github.com/devine-dl/devine/blob/master/CONFIG.md#remote_cdm-listdict)
I think option 2 is likely your easiest option
Remember, devine needs your CDM to be in a .wvd format, so the 2 files you'll download from the link given in number 2 will have to be converted into the correct format. Details on doing that are in the README of devine.Last edited by keep_it_breezy; 29th Jun 2024 at 17:51. Reason: replaced couple with few, as three is more than a couple
I picked the option 2. I downloaded from the last link. The I used this command
And I've got a .wvd file which I moved it to %LOCALAPPDATA% devine\WVDs. But I've got the same error:Code:pywidevine create-device -t ANDROID -l 3 -k "C:\Work\private_key.pem" -c "C:\Work\client_id.bin" -o c:\Work\output
Any config I should edit? Anything wrong on these steps?Code:Failed to load Widevine CDM, A CDM to use wasn't listed in the config
Good stuff - so then if you run `devine env info` you'll find the path to your config listed. Then you need to add or modify (I don't remember what it's like with the default setup anymore) your cdm line, it should look something like this :
make sure your yaml spacing and all that is correct - it's particular with stuff like thatCode:cdm: default: nameOfYourWVD
Then at this point Devine knows a) where to look for your CDM (you've already put it in the right place), and what file it's actually looking for. -
I used
and instead of wvd_name I used the path to my wvd file.Code:devine cfg cdm.default wvd_name
Apparently it generated this content in devine.yaml:
But I get this error:Code:cdm: default: C:\Users\MyUser\AppData\Local\devine\WVDs\myfile.wvd
Any idea what it can be? I made wvd variants with pywidevine using CHROME and ANDROID, L1, L2, L3, same result.Code:Failed to load Widevine CDM, C:\Users\MyUser\AppData\Local\devine\WVDs\myfile.wvd does not exist or is not a fileLast edited by elektro; 29th Jun 2024 at 18:39.
Manually edit the config to _just_ have the name of your wvd in place - Devine knows where your wvds are located (as shown by running devine env info) so you don't need to tell it twice. The `devine cfg cdm.default wvd_name` with just the name of the file (that already exists in your wvds folder) will generate something like this (if your .wvd is named myfile):
That way it looks in the path stated in your config, for the file named myfile.Code:cdm: default: myfile
@keep_it_breezy: I used only
in devine.yaml and devine still complains about this file not existing.Code:cdm: default: unknown_android_sdk_built_for_x86_16.0.0_c4e2dd1b_8162_l3.wvd
Do you have any available wvd that's good for BBC iPlayer? -
Have you tried Tubedigger in record mode?
I use it for years to download all BBC iPlayer stuff and I think I have used it to get a live concert. -
thanks, i'm new to iplayer, but it's now clear to me that they don't use drm and block non-UK ip's on the content servers.
This doesn't work outside UK
https://vs-cmaf-push-uk.live.cf.md.bbci.co.uk/x=4/i=urn:bbc:razz:ips:???:ervice:bbc_on..._hd_abr_v2.mpd -
Please help me get https://www.bbc.co.uk/iplayer/episode/m0027dkp/sunday-with-laura-kuenssberg-boosting-t...paul-mccartney in its best quality without the DRM. I'll use N_m3u8DL-RE for this. Thanks.
We all bleed blue from the inside.... -
Personally I use Tubedigger for all BBC stuff (as I said earlier) but I've just used yt-dlp with the yt-dlp-gui front-end (just to make it easy!) and downloaded the best quality version, 1280x720 50fps 48KHz AAC audio perfectly. You seem to be in New York, are you able to actually play UK BBC content?
BBC iPlayer
By Ivan in forum Video Streaming DownloadingReplies: 3Last Post: 22nd Feb 2024, 08:02 -
BBC iPlayer help needed
By Ebi in forum Video Streaming DownloadingReplies: 6Last Post: 19th Feb 2024, 17:33 -
Help / a favor to download a video "only works in the UK" (BBC iPlayer)
By Boldest06 in forum Video Streaming DownloadingReplies: 15Last Post: 28th Sep 2023, 04:20 -
How to download a program from bbc iplayer?
By fotisl in forum Video Streaming DownloadingReplies: 27Last Post: 25th Jul 2023, 10:43 -
BBC iplayer download dimensions
By David Banner in forum Video Streaming DownloadingReplies: 1Last Post: 17th Sep 2021, 15:26
