  1. Hi all,
    after a while i m trying to get keys from RTL Plus. As it was TVNow, everything works fine for me, but now i always got 403 errors, most likely my headers are wrong.
    https://plus.rtl.de/video-tv/shows/hurricane-festival-993850/2024-6-1008128/episode-30-giant-rooks-live-auf-dem-hurricane-festival-2024-993888
    PSSH: AAAAUHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADAIARIgZmRiYjdiMTA3MDc5ZTgwOGRiYzA1ZTdjZGQyMWYwNTMiBjk5Mzg4OCoCU0Q=
    Can someone explain how to build the headers right?
    Thanks guys
  2. Just pass the "x-auth-token", that's all that is required for the license request.
  3. Member aqzs's Avatar
    Mar 2024
    Paris
    HTML Code:
    Video url: https://plus.rtl.de/video-tv/shows/hurricane-festival-993850/2024-6-1008128/episode-30-giant-rooks-live-auf-dem-hurricane-festival-2024-993888
    pssh:  AAAAUHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADAIARIgZmRiYjdiMTA3MDc5ZTgwOGRiYzA1ZTdjZGQyMWYwNTMiBjk5Mzg4OCoCU0Q=
    lic_url:  https://widevine.tvnow.de/index/rtlplus
    key: fdbb7b107079e808dbc05e7cdd21f053:8ff64fd7e780ee1f3f7f24c0a04a9497
    N_m3u8DL-RE "https://vodnowusoawsdash-cf.tvnow.de/p112/cves/sd/rtlplus/993888/1-1-1-1-1.ism/v1.mpd" --save-name "Giant.Rooks.live.auf.dem.Hurricane.Festival.2024.E30" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv  --log-level OFF --key fdbb7b107079e808dbc05e7cdd21f053:8ff64fd7e780ee1f3f7f24c0a04a9497
    https://www.swisstransfer.com/d/b4e45422-1323-4fbe-ada7-e8e5969bfedc
  4. Thanks,
    i extract the x-auth-header (looks like quite long) and still got 403:
    PSSH: AAAAUHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADAIARIgZGQzZjljNzVmNzEwYWI1YjE2ZGE0YjA5OTJiNjliMjQiBjk5Mzg4NyoCU0Q=
    License Server: https://widevine.tvnow.de/index/rtlplus
    Header: accept: "*/*"
    content-length: "316"
    Connection: keep-alive
    x-auth-token: "TOKEN STUFF"
    Response:
    Error 403: {"error":"location.not.allowed","errorCode":12120,"origin":"entitlement"}
  5. Member aqzs's Avatar
    Mar 2024
    Paris
    Originally Posted by zwaen View Post
    x-auth-token: ""
    Response:
    Remove the token by editing your message it contains you IP adress.
    Add 'x-forwarded-for': '47.65.137.89' to the header to bypass geo restriction
  6. solved it... Geo blocking..
    add an x-forwarded-for header fix this
  7. Originally Posted by aqzs View Post
    x-auth-token: ""
    Response:
    Just found this in another thread, thanks for your support
