I can't believe that I don't find a decent MP4 muxer. I used Yamb before, but for years not it has reporting various errors all the time. For a while it was missing MP4 box, I don't understand how it can go missing all the time. Now it is missing some other file, always has some problems. I downloaded the software called MP4Muxer.exe. Seems to be okay but can't open .mp4. It only opens video only formats that I never heard of and don't know how to generate, for example: .h264. How do you make that file??? Than I found MP4 Tool, but that one always reports a strange error. It is trying to use some temp file in an AppData folder, but reports it is being used. Even if it is the only software open.
I am becoming tired about these. Any one knows something that works as smoothly as MKVToolnix?
.h264 is the elementary video stream, usually found in mp4 or mkv containers.
For what you are trying to do, I normally mux all the ingredients with mkvtoolnix,
then open the new mkv in Avidemux and change container to mp4.
This works fine, as long as the elements are compatible with mp4.
EDIT - Avidemux tends to ignore subtitles; perhaps a better method is a simple batch file using ffmpegLast edited by davexnet; 27th Jun 2024 at 00:12.
Use clever FFmpeg-GUI.
Load your file, click main, click multiplex, add what you want (video, audio, subs) or leave the source only, set mp4 as container, click multiplex.
Done. -
I checked the ones that you included, also others. They seem to behave differently sometimes.
It is best noticeable when you mux mp4 with ac3. I downloaded the latest Yamb, it works (I noticed the missing mp3box was the problem, even if it did report another kind of error). But it gives the worst result: the playback is fluent, but when you jump to various points on the timeline, a momentary slowing down in the video playback happens. MyMp4Box and MEGui is significantly better, when you jump first that slowing down happens, but then it doesn't any more. I found (for some odd reason), that the best is this one: https://www.videohelp.com/software/MP4-tool. With this one the video plays and jumps fluently. I always select l-smash in it as muxer, maybe because of that.
If you convert the ac3 to aac befor muxing, these problems when jumping doesn't happen. All seem to work fine. Ac3 is not a standard mp4 audio format as I know, but they always say try to avoid reconverting, so I always try to leave the audio as it is.
Is there a GUI program for MP4 files similar to MKVToolnix?
By Valnar in forum Newbie / General discussionsReplies: 2Last Post: 5th Apr 2024, 08:57 -
Avidemux (crop & resize) to output format MP4 Muxer (HEVC x265) - glitch
By mayazir in forum EditingReplies: 37Last Post: 30th Jan 2024, 23:16 -
mp4 repair untrunc GUI cant work properly/having problems
By DVDLover00 in forum Video ConversionReplies: 11Last Post: 5th Mar 2023, 00:40 -
purpose of multiplexing a multimedia mp4 file with MKVToolNix GUI?
By blanc in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2021, 10:25 -
Rewrap MTS to MP4 w/o re-encoding. Why is MP4 smaller? GUI batch tool?
By Razz in forum Video ConversionReplies: 7Last Post: 13th Mar 2021, 16:24
