Good evening,
I have a video :https://www.france.tv/enfants/six-huit-ans/tortues-ninja-les-chevaliers-d-ecaille/sais...chnodrome.html
le mpd:https://cloudingest.ftven.fr/3c05cd49b9666/269ac3a6-efcc-4b89-8ed4-64810da8aa29-171820...m/manifest.mpd
the ppsh:AAAAYXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAEEIA RIQJprDpu/MS4mO1GSBDaiqKRoFTmFncmEiJDI2OWFjM2E2LWVmY2MtNGI4O S04ZWQ0LTY0ODEwZGE4YWEyOQ==
I can't find the license (and maybe the headers) to use http://108.181.133.95:8080/
Thank you for your help to explain me where to find license
Translated with DeepL.com (free version)
Results 1 to 30 of 36
First time seeing DRM on francetv content. Here is the key :
Download command :Code:269ac3a6efcc4b898ed464810da8aa29:c9fd40e2225059bf1c172ad56e7927bd
Download link : https://www.swisstransfer.com/d/c9e7af25-174f-4152-9495-91fdc01e521cCode:N_m3u8DL-RE "https://cloudingest.ftven.fr/3c05cd49b9666/269ac3a6-efcc-4b89-8ed4-64810da8aa29-1718205635_france-domtom_DRM.ism/manifest.mpd" --key 269ac3a6efcc4b898ed464810da8aa29:c9fd40e2225059bf1c172ad56e7927bd -M mkv --save-name "tortues.ninja.les.chevaliers.decaille.S01E61.1080p.WEB"
The license url :You have to add nv-authorizations in the header. Getting keys with CDRM or others projects like those one might not work due to geo restrictions.Code:https://api-drm.ftven.fr/v1/wvls/contentlicenseservice/v1/licenses
I find the nv-authorizations but I have an error :ERROR
Wrong headers: while scanning a simple key in "<unicode string>", line 2, column 1: eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1 ... ^ could not find expected ':' in "<unicode string>", line 2, column 412: ... Eaz3rpGJmrfFFE14a_ciG4ayA1ZEUodM ^ -
You are using http://108.181.133.95:8080/ to get keys ? I never used that sorry
I use pywidevine.
Here is a small script that wll give you download command based on the video url (with or without DRM) :
HTML Code:from pywidevine.cdm import Cdm from pywidevine.device import Device from pywidevine.pssh import PSSH import requests from slugify import slugify import xml.etree.ElementTree as ET import re def getpssh(url_mpd): psshs = [] response = requests.get(url_mpd) root = ET.fromstring(response.content) for i in range(20): for j in range(20): for k in range(20): for l in range(20): try: if root[i][j][k][l].text not in psshs and len(root[i][j][k][l].text) > 70 and len(root[i][j][k][l].text) < 190: psshs.append(root[i][j][k][l].text) except: pass for pssh in psshs: return pssh def getkey(pssh, lic_token): headers = {'nv-authorizations': lic_token} pssh = PSSH(pssh) lic_url = 'https://api-drm.ftven.fr/v1/wvls/contentlicenseservice/v1/licenses' device = Device.load(DEVICEPATH) cdm = Cdm.from_device(device) session_id = cdm.open() challenge = cdm.get_license_challenge(session_id, pssh) licence = requests.post(lic_url, headers = headers, data=challenge) licence.raise_for_status() cdm.parse_license(session_id, licence.content) keys = [] for key in cdm.get_keys(session_id): if key.type=='CONTENT': keys.append(f"{key.kid.hex}:{key.key.hex()}") cdm.close(session_id) return keys def getvideo(ID): headers = {'user-agent': 'Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36',} params = (('country_code', 'FR'),('w', '1084'),('h', '610'),('screen_w', '1774'),('screen_h', '1033'),('player_version', '5.113.5'),('domain', 'www.france.tv'),('device_type', 'desktop'),('browser', 'chrome'),('browser_version', '126'),('os', 'macos'),('os_version', '10_15_7'),('diffusion_mode', 'tunnel_first'),('gmt', '+0200'),('video_product_id', '6137147'),('capabilities', 'drm'),) data = requests.get(f'https://k7.ftven.fr/videos/{ID}', headers=headers, params=params).json() mpd_url = data['video']['url'] name = slugify(data['meta']['title'] + '.' + data['meta']['pre_title'], separator='.', lowercase=False) if 'drm' in mpd_url: pssh = getpssh(mpd_url) TOKEN = requests.post('https://k7.ftven.fr/drm-token', headers=headers, params=(('v', '2'),), json={"id":ID,"drm_type":"widevine","license_type":"online"}).json()['token'] key = getkey(pssh, TOKEN) print(f"""N_m3u8DL-RE "{mpd_url}" --save-name "{name}" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key """ + ' --key '.join(key)) else: print(f"""N_m3u8DL-RE "{mpd_url}" --save-name "{name}" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF""") # urlvid = 'https://www.france.tv/enfants/six-huit-ans/tortues-ninja-les-chevaliers-d-ecaille/saison-1/6137147-irma-se-fait-remarquer.html' DEVICEPATH = "device.wvd" urlvid = input('Video url: ') r = requests.get(urlvid) matches = re.findall(r'"videoId":\s*"(.*?)"', r.text) if matches: videoid = matches[0] getvideo(videoid) -
You can use this much simpler script if you just want the keys :
HTML Code:from pywidevine.cdm import Cdm from pywidevine.device import Device from pywidevine.pssh import PSSH import requests lic_token = input('token: ') headers = {'nv-authorizations': lic_token} pssh = input("PSSH? ") pssh = PSSH(pssh) lic_url = 'https://api-drm.ftven.fr/v1/wvls/contentlicenseservice/v1/licenses' device = Device.load("device.wvd") cdm = Cdm.from_device(device) session_id = cdm.open() challenge = cdm.get_license_challenge(session_id, pssh) licence = requests.post(lic_url, headers = headers, data=challenge) licence.raise_for_status() cdm.parse_license(session_id, licence.content) for key in cdm.get_keys(session_id): if key.type=='CONTENT': print(f"\n--key {key.kid.hex}:{key.key.hex()}") cdm.close(session_id) -
the script not work : python3.10 pywidevine.py
File "/home/Bureau/N_m3u8DL-RE_Beta_linux-x64/pywidevine.py", line 1, in <module>
ModuleNotFoundError: No module named 'pywidevine.cdm'; 'pywidevine' is not a package -
The script works for sure. Rename it other than pywidevine, it's the name of the library you are using, you shouldn't name a file the same as a lib, it's confusing for python. Since you never used pywidevine before install it using :
In the code I provided you also have to change the path of device.wvd with your own one. You can get a CDM following this thread : https://forum.videohelp.com/threads/408031-Dumping-Your-own-L3-CDM-with-Android-Studio or grabbing one from here : https://forum.videohelp.com/threads/413719-Ready-to-use-CDMs-available-here%21Code:pip install pywidevine
I use second link I download private key client id
the script :import sys
from pywidevine import Device
if len(sys.argv) < 2:
print(f'usage: {sys.argv[0]} <private-key-file> <client-id-blob> or {sys.argv[0]} <file.wvd>')
sys.exit(1)
if len(sys.argv) >= 3:
with open(sys.argv[1], 'rb') as f:
private_key = f.read()
with open(sys.argv[2], 'rb') as f:
client_id = f.read()
device = Device(
private_key=private_key,
client_id=client_id,
type_=Device.Types['ANDROID'],
security_level=3,
flags=None)
else:
device = Device.load(sys.argv[1])
print(device)
I have an error: python3.10 device private_key.pem client_id.bin
File "/home/Bureau/N_m3u8DL-RE_Beta_linux-x64/device", line 19, in <module>
AttributeError: type object 'Device' has no attribute 'Types' -
I use your script :
python3 pywidevine.py
token: eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiIsImtpZCI6IjkxNT YyMCJ9.eyJ0eXAiOiJDb250ZW50QXV0aFoiLCJ2ZXIiOiIxLjA iLCJleHAiOjE3MTkyNjgxOTIsImNvbnRlbnRSaWdodHMiOlt7I mNvbnRlbnRJZCI6IjI2OWFjM2E2LWVmY2MtNGI4OS04ZWQ0LTY 0ODEwZGE4YWEyOSIsInN0YXJ0IjoiMjAyNC0wNi0xM1QyMjowM DowMFoiLCJlbmQiOiIyMDI0LTA2LTI1VDA0OjE5OjUyWiIsInV zYWdlUnVsZXNQcm9maWxlSWQiOiJIRF9IRENQMCIsInN0b3JhY mxlIjpmYWxzZX1dfQ.Zee7SRH20-NEaz3rpGJmrfFFE14a_ciG4ayA1ZEUodM
PSSH? AAAAYXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAEEIARIQJp rDpu/MS4mO1GSBDaiqKRoFTmFncmEiJDI2OWFjM2E2LWVmY2MtNGI4O S04ZWQ0LTY0ODEwZGE4YWEyOQ==
File "/home/ludo/Bureau/N_m3u8DL-RE_Beta_linux-x64/widevine.py", line 15, in <module>
File "/home/ludo/.local/lib/python3.10/site-packages/requests/models.py", line 1021, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 400 Client Error: Bad Request for url: https://api-drm.ftven.fr/v1/wvls/contentlicenseservice/v1/licenses -
Probably token expired (decoded):
The "exp" timestamp resolves to Tue, 2024-06-25 00:29:52, and "end" is over as well.Code:{ "typ": "ContentAuthZ", "ver": "1.0", "exp": 1719268192, "contentRights": [ { "contentId": "269ac3a6-efcc-4b89-8ed4-64810da8aa29", "start": "2024-06-13T22:00:00Z", "end": "2024-06-25T04:19:52Z", "usageRulesProfileId": "HD_HDCP0", "storable": false } ] } -
Hi is there any update to this script seems the France TV format has changed
For instance www.france.tv/france-4/goldorak/goldorak-saison-1/6795535-les-freres-de-l-espace.htmlLast edited by Prefus; 8th Jun 2025 at 11:48.
thanks dunno how i managed to have it work but it seems to process flawessly
a huge thanks for everyone so helpful here on this forum ! -
Having a similar issue here: https://www.france.tv/france-4/belfort-lupin/saison-1/7176185-les-100-ans-de-madame-rosa.html
How do I download drm content with yt-dlp ? -
review
yt-dlp --allow-u -F "https://cloudingest.ftven.fr/ftv/4/5f/45f4c383f1286/75e61b92-49ed-4dbd-ad07-f1febd5003a3-1747055946_france-domtom_DRM-SEC1.ism/manifest.mpd"
download
yt-dlp --allow-u -f video=4993000 -N 20 -o video.mp4 "https://cloudingest.ftven.fr/ftv/4/5f/45f4c383f1286/75e61b92-49ed-4dbd-ad07-f1febd5003a3-1747055946_france-domtom_DRM-SEC1.ism/manifest.mpd"
yt-dlp --allow-u -f audio_fre=96000 -N 20 -o audio.mp4 "https://cloudingest.ftven.fr/ftv/4/5f/45f4c383f1286/75e61b92-49ed-4dbd-ad07-f1febd5003a3-1747055946_france-domtom_DRM-SEC1.ism/manifest.mpd"
But why use yt-dlp when you can download and decode directly using N_m3u8DL-RE?
Code:N_m3u8DL-RE "https://cloudingest.ftven.fr/ftv/4/5f/45f4c383f1286/75e61b92-49ed-4dbd-ad07-f1febd5003a3-1747055946_france-domtom_DRM-SEC1.ism/manifest.mpd" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:142.0) Gecko/20100101 Firefox/142.0" -H "Accept: */*" -H "Origin: https://www.france.tv" -H "Referer: https://www.france.tv/" --key 75e61b9249ed4dbdad07f1febd5003a3:c9b60714dd7932575e67aef9a1b0f179 --use-shaka-packager -M format=mkv
Thanks everyone for all the info shared above.
I am new to the subject and no matter what I try it seems impossible to download this episode:
https://www.france.tv/france-5/echappees-belles/saison-18/7268561-corse-l-ile-aux-tresors.html
Anyone able to help please ?
Thanks -
https://cloudingest.ftven.fr/ftv/c/59/c5930576cf486/5b834e1f-7c8f-488b-9a56-13f1c0ae46f0-1750060207_france-domtom_DRM-SEC1.ism/manifest.mpd 5b834e1f7c8f488b9a5613f1c0ae46f0:54384d3d45b33fb8a2156f43a8c0b2ce
Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2 -
Also can someone recommend a good VPN to use? I'm in the United States so I'm geo blocked. Preferably one that uses openvpn. I don't wanna install any sus apps onto my computer. I use Linux also so I can't do anything that involves a exe. file anyways. I was using vpnbook for a bit but it suddenly stop working for me.
Edit: Nvm! I found a vpn that works. The only thing I'm still stuck on is getting the keys. Seems like people using pywidevine? I looked it up, and my brain is melting trying to figure it out.Last edited by amarok94; 12th Sep 2025 at 21:58.
to find keys and command to download with N_m3u8DL-RE, install WidevineProxy2
https://forum.videohelp.com/threads/416316-%5BRelease%5D-WidevineProxy2-Extension-Bypa...s-Lic-wrapping
Free L3 cdm available
https://forum.videohelp.com/threads/417425-Real-Device-L3-Cdms -
Thanks once again!
All issues sorted with the help of sticky and a little search n the forum + trial and error.
I can now extract manifest + kid:key and archive the required file on my Pc.
Many thanks to the forum and everyone's help!
Can you use the Widevineproxy2 plugin to download drm content from youtube for free movies?
mp4decrypt --key KID:KEY encrypted_video.mp4 decrypted_video.mp4
https://www.bento4.com/documentation/mp4decrypt/
or
shaka-packager
https://shaka-project.github.io/shaka-packager/html/documentation.html#encryption-decryption-options
Convert drm mpd source to simple mpd or m3u8 without drm.
By alberto404 in forum Newbie / General discussionsReplies: 0Last Post: 5th Aug 2023, 11:05 -
restreaming to non-drm m3u8 from drm mpd
By grabyea in forum Video Streaming DownloadingReplies: 1Last Post: 8th Aug 2022, 00:35 -
DRM Live NO, DRM VoD YES.
By d0b in forum Video Streaming DownloadingReplies: 49Last Post: 7th Oct 2021, 15:41 -
Download DRM protected video and decrypt it with a drm licence url
By vikral in forum Video Streaming DownloadingReplies: 9Last Post: 9th Feb 2021, 02:14 -
[franceTV / akamai] Unreliable m3u8 download, frequent small corruption
By abolibibelot in forum Video Streaming DownloadingReplies: 0Last Post: 18th Dec 2020, 17:24
