I want to setup a dual drive boot system with windows 10 on one M.2 drive and windows 11 on another and alternate back and forth between both OS overtime. Both OS will access files on a third and fourth M.2 drive. On both of these OS will be editing software like Premiero Pro that will access their own videos from a third M.2 drive. I'm doing this as some apps work well in windows 10 and some only well in windows 11. Also the same goes for games, some only work on windows 10, I want windows 11 to be designated for more modern games, again I would have the fourth M.2 drive for all my game storage.
Again, the same goes for viewing videos and photos within each OS that are stored on desiginated drive.
So is there any problems with this? Any unforseen issues that might arise? Like any corruption of folder and image/video thumbnails?
thanks.
The thing you have to watch for is when you edit video/pic on one system and delete the originals then you will get issues depending if the software remembers the video last loaded so you might get messages about corruption or similar on the other system but as long as you remember the files you edited there should be no issues.
Most (good) NLEs are non-destructive editors: they apply changes to a virtual timeline, or to clips, as per a "script". So the original media is rarely changed, only the resultant exports are, and those are newly created. An NLE used in one boot scenario would have no knowledge of newly-created files from an NLE session of a different boot scenario. But it would treat those files as it would any other filesystem file: ask if you wanted to overwrite/skip, etc, or would ignore them if they weren't pertinent to the new session.
The danger is when using "destructive" editors, which DO apply changes to original clips.
Using those supplemental drives for content is not a bad idea, but it is probably a best practice to use a non-NTFS file system, since an NTFS filesystem - which follows stricter file ownership privileges - might lock one out of a folder or usage of a file, since the ownership is different from one boot setup to another (GUIDs of owner are different even when name may be the same). Since FAT has a 4GB limit, use something like exFAT. That way, all files/folders on those drives are accessible from either boot partition.
large files sharing
By marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 16th Oct 2022, 23:51 -
Hard Drives Syncing Question: Same Copies Under Different Folders in Drives
By 75er in forum Newbie / General discussionsReplies: 14Last Post: 8th Sep 2022, 19:58 -
Sharing snapshots from 4 different capture methods
By brockway in forum Capturing and VCRReplies: 9Last Post: 4th Nov 2021, 08:23 -
Sharing 4K videos with family and friends
By spapakons in forum Authoring (Blu-ray)Replies: 14Last Post: 10th Apr 2021, 08:26 -
Video Sharing Platform
By videoquestion123 in forum Newbie / General discussionsReplies: 3Last Post: 10th Oct 2020, 03:27
